Sanding models
Is it necessary to sand models? e.g Tamiya car body. Or do people mainly sand between 'fused' parts?
What kind of grit sand paper or wet and dry would I need?
If you want to key the surface before painting then I would use minimum 1000 grade wet and dry. 1200 - 1500 would be better though.
Hi os40 i dont know if my answer will help but i dont normaly sand before unless there are inperfections in the plastic and to get parts to fit correctly But i dont do cars with super gloss finishes
os40. If you do not provide a key for your primer it is more likely to flake of especially as you sand your primer to receive the top coats.
Also I understand that the plastic has the remains of the factory production release agent still attached.
I wet & dry the surface which will do two jobs,. Get rid of the release agent remains & provide a good key for your primer coat. Good idea to rinse after sanding as this will get rid of any debris. I use an 1800 wet & dry paper. One that has been used before so it is nice & soft & goes around the round parts easily.
Hi os40 , I don`t sand the bodywork before priming but I do wash it first ( luke warm water with a touch of washing up liquid and an old tooth brush ) to get rid of any oils or release agents on the plastic , I then use halfords grey or white primer and never had a problem yet , between coats I sand with a very fine sanding stick .
saying that some people do sand before washing the choice is yours , with my method I`ve never had any major dramas yet and it seems to work for me.
Richy
ps - if you wash the model first ( recommended ) don`t use hot water it could soften the plastic and put it out of shape , I also recommend drying it off with a kitchen towl then leave overnight to finnish off drying naturaly .
Laurie you beat me to it mate , I keep getting done like this LOL .
Richy
That OK Richy yours had a different flavour & some more info.
Like your Churchill quote. Heard this one in which is in a a similar vein.
Nancy Astor: “Sir, if you were my husband, I would give you poison.”
Churchill: “If I were your husband I would take it.”
I hate sanding! I only do it where I have to,accross a seam for example. I use Halfords plastic primer. It sticks like sh+t to a blanket.
Thinks must never get Halford's plastic primer next to my blanket.
Deep thinks again not a problem I use a duvet.
Hi OS!
I usually wet-sand before primer, I use a grit close to the primer that I plan to spray. After that I sand 1000-2000 grit between each layer of primer, paint, and gloss coat. There is not really any way around all this sanding if a glossy show-room finish is what's you're after. Check out Alex Kustov's tutorial on his website: How to Apply, Polish, and Wax Your Paint to Perfection
If your in to car-modelling, his site is a gold-mine
Happy digging!
/Daniel
