Hi All,
Recently someone ask about SCALES and how it related to the actual item, be it a aircraft or a tank. He got his replies and hopefully understands now.
I have just come across some scale rulers on a website, that you can print-out. If you stick one of these onto some platicard you have a ruler to measure you models in Feet or Metres, As per the image attached. The truck is 7 metres long?? or about 19cm..
They can be found at hungrylizardstudio'>www.hungrylizardstudio.com/ssm/32-100.pdf
Hope it helps
Regards
Mel.
Hope it helps
Regards
Mel.
