scanlons sinking tube thing!
After the AMX, I thought I would try and finish the Pacific Coast Hurricane from under my bench but found I was still fighting and had wasted enough of my life on it, so I thought I would start this one, a nice simple build!! Trumpeter had other ideas,
I found two prominent seam lines on the lower hull which took some work to shift
and even better the hull halves are different lengths!
anyway I have shimmed it to take the worst out of it and will now look forward to more filling and rub
Thanks for looking.
\ said:
this will be interesting.....cant believe those two hull halfs are so far out! :eek:
Yeah they seem to have gone to sleep on this one, still a nice big lump though, just realised this should be in the submarine section.:oops:
\ said:
Looks like some work in store for you there Steve
You are right there Ian, on the lower side there panels that I will have to re scribe as they pass over a joint.
Wow Steve you would think that big of an error would've been corrected before the kit was released! I'm sure you'll whip it nto shape all the same.
