Scotties Humber lll
scottie3158
Oh no he's back again already I hear you cry. This time I have the Bronco, Humber Armoured Car Mk lll. I was going to do this for the D Day build but it appears it wasn't used the MklV was however. For a smallish model just over 13cm the large box is packed with plastic. The kit contains no fewer than 15 tan coloured sprues, 1 sprue moulded in green of personal equipment, 2 etch frets, 1 clear and a small decal sheet giving 3 options for Europe, Italy and Tripoli.
The Humber Armoured car was produced up until the end of the war but was still in use with many countries until the 60's. All Humber cars were 4x4 but could be switched to 2 wheel drive which was the norm. It was powered by a 90HP 6 cylinder petrol engine. It's primary role was reconnaissance in all theatres other than the eastern front. It was fitted with a larger turret to accommodate a 3rd crewman to operate the radios. It was armed with a 15mm BESA Cannon and a 7.92 BESA machine gun. These were sometimes removed and fitted with dummy guns to accommodate another radio.
Hope you can join me along the way.
Scottie
There certainly is a lot of plastic for such a small model. Lets hope the high parts count equates to great detail and not just lots a fiddly bits. Whatever the case I'm sure we're in for a treat. Nice to see personal equipment included. Do you intend to source figures?
OOB or not OOB - that is the question!!
As it's a 'Scottie' build methinks we know the answer!!!!
Whichever he decides, I'm sure we will be in for a treat. :thumb2: :smiling5:
Oh no he's back again already.......
Sorry but you know what they say about bad pennies :tongue-out3:
Jim, there is and should make for a nicely detailed build. I have some figures that I can use. I just need to have a think about what sort of scene I intend.
Doug, this really should be mostly OOB as it seems to be quite detailed but I might find something :tongue-out3:
I'm in.
15 sprues plus your usual sprinkling of scratchmongery, this will have an epic parts count by the time you're finished!
Count me In, Paul. Hoping that you're providing better concessions than your last recent show. Left a bit to be desired. Just so's you know....;)
Partly, that’s because it has a full interior :smiling3:
very true mate.
I'm in.
Andy, given the detail hopefully I won't have a lot to do.
Ruck On, Scottie/Paul!
Cheers Steve.
Count me In, Paul. Hoping that you're providing better concessions than your last recent show. Left a bit to be disired. Just so's you know....;)
Ha ha Ron, sorry I will try harder mate.
I'm in , always love a Scottie masterclass
Cheers Mick I will try not to disappoint.
I have made a start. This is very well detailed but so many parts and they are tiny. A sharp blade and snips is a must.
The engine is not for the faint hearted. the radiator is held in place by two very thin struts and the hoses with no real location holes. In the end I drilled the hoses out and put some 0.3 mm wire in to hold the joints while they set and give them some handling strength. The only addition is some HT Leads.
And the hose on top was replaced with copper wire as the kit one snapped.
cheers
Scottie
Oh what a lucky model to have you showcasing it!
Will be watching as always:thumb2:
Jim.
I do like this little WWII armoured cars - a great subject.
Great stuff thus far, that engine looks like it'll be a cracker under some paint.
Sorry guys that it took so long to reply.
Jim.
Jim it's good to see you again mate it's been a while.
My god not you again!!
All was a treat to see your work Paul.
Fraid so mate there is no escape lol.
Arnold, I like them as well I have already build a Humber Mkl
I'm always in for British armour Paul, looking forward to seeing what you do with it.
Cheers Graeme hope I don't disappoint.
