I'm in the process of building the Thunder Tiger Victoria Yacht. I'm doing the electrics at the moment but I seem to have hit a bit of a snag - I'm using a Hitec HS422 servo for the rudder (see attached picture) and I was going to send for an HS765HB Sail Servo, but I see that it measures 5cm in length but I only have space for 4cm on the mounting board unless I cut the end away. Can someone please recommend a Hitec Servo that will be OK for the sail arm and will fit into the 4cm gap. I'm sure someone on here will be using Hitec stuff - or at least I hope so. Many thanks in advance
Periscope
Periscope
