spevtrum rc 6 channel set
for thos of you aware what spectrum rc is , it`s only been ) upto now available on 3 channel sets.... however a new 6 channel set is aimed at park flyers and small aircraft.
http://www.spektrumrc.com/DSM/Better/DX6-glance.html
spectrum uses the 2.4Ghz band and has aprox 72 `slots` available, simply put when you arrive at the pond,runway or track, you set up your equipment which takes a few seconds, the Tx finds a free slot in the band, and then you `match` the Rx to the Tx, if there are no unused slots available, then you will not get a match and cannot use the equipment , foolproof !
has been tested by car and some hi speed boat owners as well as yacht owners with good results and feedback but up unitil now only 2 or 3 channel options available. the good part is the price $199.99 , for a full set withy with mini servos.
:wish:
