Greetings Everyone!
I am starting on a New Larger Scale ST:TMP DRYDOCK made to fit the DeBoers Scale Enterprise. Right now I have most of the model blueprinted for the sections that I need for reference for when I actually start construction.
I will have a serious advantage with this build in that I was able to go see the original DRYDOCK model in person. From this I was able to make hundreds of notations and many reference pictures of this incredible miniature. On my first Drydock build I had only ST:TMP DVD as a reference and whatever photos that were floating around on the internet at the time. But now I can be as accurate as possible with this new scale. The only thing I would like to point out though is please, please do not ask me to post any of the pics that I took of the miniature. I was allowed in good faith to take the pics that I did as long as I would not publish them. So, please be considerate of this request. There will be no further discussion of this issue and private requests will be deleted. Thank you for respecting this wish.
The only thing I can assure you of is that what you see in this build will be a very accurate representation of the model. With that in mind, this last month I was able to start construction of a MASTER of one of the light panels. This will be used for mold making and YES, this time I will be casting the majority of the parts for this build. This should cut down the build time dramatically. I am going to be casting the parts in black resin to reduce the need to opaque the pieces for light leaks. I will also be trying a new kind of lighting that will reduce the need for soldering, LEDs and exposed wiring and excessive heat build up.
I have also been asked to work out some moldings and castings for another 1/350 scale drydock build. These updates will be included on the DRYDOCK LARGE SCALE page. By the next update I am hopeful to have some of the moldings done and a few of the castings ready for pics.
In the Updates for March I just have one pic of the Enterprise models in their cradle docks. These cradles make it much easier to not only move the models, but also to work on them. Shoulda finished these months ago but..... busy. Anyway, on the drydock page I have several drawings of the model-to-be's basic designs and some pics of the light panel Master. I will have more of the details added on by the next update. See you then,
Mark
Home - NemVia Productions
Mark
