ST:TMP Drydock (WIP)
Hi everyone!
I apologize for the long intervals between updates, but for October all I did was a lot of drilling and aligning and drilling and aligning and..... well, you get the point. So, I thought I would wait an extra month so you can at least see some progress with the dock.
Because using metal in model construction is not a forgiving as with plastics, one has to be more precise with the drilling and bending of tubing and other pieces, so yes, it does take a little longer to get things done, but I'll tell you, in this case at least it will be worth the wait.
In this month's update I've finally been able to test fit some of the panel frames with the main modules. As I said In other updates I needed to wait for some parts to come that were back ordered. The back ordering occurs because of the quantity of items that I need for these projects. I've had to order 164 copper tubes, about 56 or so threaded rods and a couple hundred dome and regular nuts and so forth. I've had to cut a lot of these items to length and make sure they fir properly into their respective pieces. This is definitely a take-your-time and do-it-right-the-first-time projects(s).
Other than the panels frames, there will be very little to solder together. Following the design of ST:TMP filming miniature there will be a lot of screws, nuts and bolts holding this baby together. If you watch all of the drydock scenes including the Enterprise leaves drydock you will see a lot of these details right on the screen.
But anyway, this isn't a just drill it and put it together project. This updates I've started by adding the anchor cone pieces to the outside parts of the overhead module, then I have to take each panel frame individually make sure that each of the holes both on the module side as well as on the side and bottom frames will line up. I've started on the top tier of frames on only one of the module pieces. Now that I know what to do I can get the other tiers lined up and in place. With all of the threaded rods and dome nuts in place I was very pleased to find that the panel frames are able to support their own weight so when all of the pieces are finally in place I will not need additional supporting rods to hold everything up as I did with the 1/350 PLE drydock. This is also something that TMP dock was able to do.
All the pics in this month's update are pretty much test-fitting pictures to make sure everything lines up correctly. I will not be able to permanently weld everything together until I can get the wiring in place for the light panels and other effects. There are 19 new pics in the November Updates tab.
By next update I hope to have the tiers finished on at least one of the modules. We'll see how it goes. I will try to get as much done as possible in the next month because December is a very bad month for me secular jobwise, so I hope you enjoy the new progress pics and hope to hear from you. All comments positive and negative are welcome!
For those of you visiting for the first time, please sign up as a member and be the first to receive notice of any updates on my site.
Talk to you next month! Take care and Happy Modeling!
Mark
December Updates
Well, here we are! Another month goes by and we are already into December.
I have 10 new pics for your viewing the DECEMBER UPDATES - 2013 page on the left sidebar menu on my site. I've spent the good majority of November working just on the panel frames. The hole alignments have to be pretty precise so it takes quite a bit of time to get everything just right. For each of the sides, both port and starboard, I could only fully assemble five panel frames each with all three tiers. The reason being that the last to panels on the fronts and rears of each side on all three tiers need to be left unsoldered together so that I can thread the lighting effects through the end sections and through the tubing of each tier and to each light panel.
Did you get all of that? Well, if you didn't just wait for the wiring update and you'll see what I'm talking about. But so far, everything is fitting in place and all of the tiers seem very sturdy and will be able to support their own weight as they will be freely hanging from the sides of the overhead module. There should be no supporting rods like I needed with the 1/350 drydock model for this build.
In other news, which in this case is GOOD news, I was able to get the Drydock's steel frames back from the welder this week. They are built very similar to the 1/350 scale version except that I am not using copper piping. These frames are made from steel to support the weight of both the dock and the DeBoers Model. I will now be making the necessary holes in the overhead modules to anchor them to the steel frame. After this is done I will be drilling out all of the holes needed in the support frame to bolt the modules to it as well as holes for casters that will be used to move this large model around to be worked on. I have made this frame so that the lower section or Dolly can be removed so the model can be hung on a wall of my client so desires. Anyway, after the holes are all drilled out I will be sanding the entire frame(s) down and spraying the entire assembly with Rustoleum to prevent any more oxidation on the metal.
December is usually an unfruitful month for me as far as work on the models goes. Our company gets quite overwhelmed with work during this month, so the January update might be a little lean with pictures, but we'll see how everything goes. Well, that's my update for this month!
Hope everyone enjoys the pics! As always, be safe and happy modeling and I will see you in January! Take care,
Mark.
Hey! Been busy this month But should be able to resume work on the dock. Just minor updates on my site. Give me a few more weeks and I'll have some new pics!
Thanks, Mark
For the 1/260 Drydock Updates, I have added the latest progress pics in the February updates page. I've been able to sand down the steel frames to prepare them for spraying. They will be sprayed Flat Black to hide the fact that they are supporting the models. I put a couple of pics to show how the frame can be mounted to a wall for display. For the rest of this month's update I had to cut holes into the overhead module side panels to allow the support tubes to slide through. Then I was able to bolt the module frames to the tubes so they are now permanently anchored to the frame. I've also started adding the anchor cone pieces to the center sections of the modules. These have to be done one at a time to make sure the anchors line up with the holes on the modules. There are 70 of these total on each of the Drydocks.
I've also ordered some Dry-Transfer Lettering that will later be used to mark all of the light panels according to ST:TMP flyby scene. During the month of February I will be drilling the tension rod holes for all of the light panels and their frames and then mounting all of the panel frames to the Port side or rear Modules. If I can get all of this in place I will be able to start threading the EL Wire for the lighting effects. Take care for now and I'll see you next month!
Mark
That is one detailed drydock, superb Mark and the posts you are making are interesting too, should look amazing when finished.
Si:)
March Updates are now posted! I have about 30 new pics! Enjoy
This month I have been able to get somewhat back on track. The weather has warmed up enough for me to go back into my garage to do some of the necessary work that can't be done inside our house.
I have 23 New Pics in the April Updates. Here are the details:
I have finally received the armatures for the models that will be used to marry the Enterprise models to the docks. They are made of 1/4" hollow tube and are quite sturdy. I had them welded together in a specific manner so that they will be hidden as best as possible inside the dock and the ship giving the illusion that the ship is floating inside the dock.
All of the copper tubes that I cut the holes into have been placed inside the panel frames. These will be used to support the light panels as well as allow me to run the lighting effects through each of the tubes.
I have also started painting the light panels their respective colors. This took about a week to do. I was able to finish those and start work on the dry-transfer numbers and letter that are on each of the panels. In ST:TMP the dock was heavily decaled only on the side that was visible on the screen. The side unseen or port side has decaling but not to the extent of what Row "E" of the panels has. As I have more time I will be adding more of the decals to each of the panels since this will be a full model of the dock. The bummer about the dry-transfers is that they only give you so much of certain letters and/or numbers. For instance many of the panels are numbered in the 30's and 70's. Guess which numbers they give you the least amount of? Yeh... 3's and 7's so I have to order many many sheets of the transfers and then try to use the other numbers just so I don't waste too many of the decals. But.... hey.... that's the life of a model builder, huh? Anyway I think Row "E" which is seen on the screen turned out rather nice.
Now, another feature of the Light panels is seen on the upper right and left side of each of the panels. Since I don't know what they really are I am going to call them the power nodules for the light panels. I used reference pictures from the movie as well as some pics I shot of the Filming Miniature to scratch build a highly detailed master so that I can cast all of these pieces rather than build them all individually. Just a side note, it took me about 4 hours total to create just one of these from scratch. The only thing left that I need to do for these pieces is build the 2 tanks or bottles that are seen on the top and bottom of the light panel support poles. These will be cast separate from the nodule pieces as well as a clamp-like piece that connects these nodules to the light panels. I should have them done by the next update.
Last but not least I am taking some new measurements for some interior sections of the dock can be seen from the outside. I am going to do what I did for my 1/350 scale dock and that is add a large interior Hanger bay that can be seen by looking into the Aft End of the dock though the hanger doors. I have a lot more room to work with on this dock and I purposely made the support frame so this dock can be a lot larger than the 1/350 version. You will be able to see many Shuttles, work bees, Shuttle pods, cargo containers and other details. This should help give a great depth of scale to the model and how large it would be in real life.
Hopefully by next month's update I will have some of the panel frames painted up and ready to be connected to the Overhead modules. Hopefully there will be no Hang-ups or snags. The weather is getting better, slowly but surely. This will make things go a lot faster. 'Til then, see you next month!
Mark
Hey Everyone!
This month I've spent quite a bit of time casting many different pieces for the Light Panels as well the panel frames. The focus was mainly on the Power Nodules that are seen on either side of the tops of each of the side light panels. I needed to cast these parts in two different pieces because of the complexity of each part. There are 84 nodules on each of the docks so I had to cast 84 nodules as well as 84 of the clamp pieces.
There are also 2 tanks that are on each of the nodules that I needed to build from scratch. There are 168 of these needed per dock, so I made castings of those and painted some of them light gray. The end pieces on all of the tanks will be hand painted neutral gray. When the Nodules are finally painted I can then cement all of the tanks to the Nodules. Whew! A lot of work in the coming months.
Other parts that needed to be cast were the box like recesses that are seen underneath the overhead modules. There are 7 per module. They were challenging for me to cast because of how thin the walls are. Added to that was also a slit on the front and back parts of these pieces that are used for allowing light to shine through for additional effects. I never knew these slits were on the model until I was able to see the Drydock Miniature in person. Be assured they are there, they just never had any screen-time in the movie.
In other updates you should know that despite all of the obvious details seen on the Overhead modules there is also an abundant amount of details that follow the inside and outside parts of all of the framework for the side panel frames. I made up 8 different versions of the detailing and made molds of them. Now when I add them as details to the dock I can use them at random and also flip them upside down so they will appear as even more details. These will be used for the horizontal parts of the framework. I also made up 3 additional detail pieces for the vertical parts of the framework which also can be flipped over for different details. I found it was faster to use more that enough resin so that I can pull all of these pieces out of the mold at the same time, then use a belt sander to get rid of all of the excess resin and thin out the strips. You'll see what I mean in the May Updates page.
I have been able to apply the horizontal strips of details to the panel frames where the anchors hold the frames together. Eventually I will be able to start painting the frames and assembling them to the modules.
In The last week or so I have started painting the Power nodules. I applied the first color which is Intermediate blue and I've started masking off the nodules to add the second color which will be Rust. Later I will hand paint some of the smaller details with a small brush. I was hoping to get at least one of these done for this month's update but I just couldn't get that much done. Sorry! I tried. When I get one of them painted up I'll post ASAP. And last but not least I've begun casting pieces for the hanger bay for the overhead module. I'll have some pics for that next update. There are 25 new pics in the May Updates page! Enjoy! and I'll see you next month!
Mark
Hello Fellow Model Builders!
Although I don't have a lot of update pics for you this month, I have done I good chunk of painting details onto many, many pieces. The square box insert pieces for the overhead modules have been airbrushed to their final color and the lighting slits have been cut into each of these pieces. I have a good pic of one of these as a test fitting pic in the June Updates page.
Another chunk of the work load for this month was hand painting some of the details for the Light Panel Power nodules. There are 4 different colors on each of these pieces now and there are 84 of these pieces for each drydock model that needed to be painted. I have also been hand painting some of the details on the end caps of the tanks that will later be cemented to the power nodules. IT's easier to cast them in groups of 4 and paint them while they are still on the sprue pieces. When they are finished I can just snap the tanks off and then cement them onto the nodules. I'll have some pics of that in next month's update.
As long as I had my airbrush out I started to paint some of the vertical detail pieces for the light panel frames. I first had to sand down the back parts of these pieces so that they are now pliable enough and can now be curved with some amount of ease when they are put onto the panel frames.
That's what I have been doing for the most part for this month. But I also figured out how many more of each of these pieces that I need to finish the model and have been doing a lot more resin casting. By next update I should have all of the needed pieces cast and then painted and THEN I can get to work assembling all of the parts.
In the next month I will also be working on the hanger for the overhead modules. I know I started that a few updates back, but I really needed to concentrate on getting all of these detail parts cast and painted. You should start to see the beginnings of the work crane and work light modules and booms in the coming months.
Thanks for being patient with this build. I know it's taking a while to get anywhere, but soon I can assemble everything and then we will start to see some awesome results. Keep checking for updates and I'll see you next month!
Mark
Hi everyone. Just letting you know that the update for July is bare minimum. Had to go on vacation for a couple of weeks (Had to! Yes needed to. I needed a break gaaaaaah!) Anyway, I only did some casting for some of the detailing pieces as well as some sanding and painting. Most of this stuff was seen in an earlier update, so I won't publish similar pics on the sight. I will be starting on the assembling and painting the Starboard side of the drydock and will have some new pics for you for August. Thanks for your patience and I'll see you then.
Mark
Some lovely work there Mark. Hope you have/had a great vacation and a well needed rest. Look forward to the upcoming work.
Si:)
August Updates 2014
Okay! Back on track. At least somewhat. Because of the complexity of the Drydock build, you can just imagine how repetitive some of the work can be especially when there are 2 being built at the same time. WOW!
Never again. At least not 2 builds at once. Anyway this month I can report some decent progress. In the past updates, you have seen the overhead modules in their natural molded black color, then the next color went to Italian Brown, but that was never to be the finale color of the modules. In doing research for my original 1/350 scale dock I viewed as many production stills, behind the scenes photos and even the old trading card pics as I could get my hands on and I found what I believe to be the closest color match as possible for the final color of the dock. In many of the stills There appears to be a reddish tinge to the color of the dock. When I took pictures of my 1/350 scale version the colors seemed be quite close. I like that Rust color, so I am using this for the final color of the dock. But I will not be laying it on too thick. I want some of the brown to show through in a subtle way. This would also give it a more used and weathered look.
To start out with the painting I needed to fix almost all of the corner pieces of the modules. This being my first major resin cast project I did not get everything to line up exactly. But with some styrene and super glue I was able to fix all of these parts up. Next I wanted to add in all of the remaining anchor cones so that they could all be sprayed at the exact same time. This would mean less touch-up work later on. The reason I didn't add all of the cones sooner when I was assembling them early on was because I was going to use some of these cones to thread wiring through them for some of the lighting effect. But I now, I've come up with a new way to add the lighting which I will discuss in future updates. So anyway, I fixed all of the loose parts by either re-cementing or replacing them so that everything will be ready for the final paint job. Next I did some more masking of what look to be grill plates on the underside of the modules. I also masked off a lot of the side panels to give a little bit of a variety in color. Then I sprayed the entire model which took me just under an hour to do for each model. The spraying time was mostly taken up by doing all of the anchor cones.
There are some pretty good pics of the paintjob on the AUGUST UPDATES 2014 page.
After all of the masks are removed you can see the different colors on the underside and sides of the modules.
I was also able to start adding the starboard side panel frames to one of the models. This took some doing because I needed to added the support rods through the modules. After I had originally built each panel I had to align them with their proper positions mark all of the drill holes off one at a time to make sure all of these pieces would fit properly later on when they would be connected to the modules. To make sure I didn't mess up their order I needed to number all of the tiers so that they could be placed back into their original positions.
The Starboard frames are now anchored to the modules but they still need some tweaking. To finish all of that though I need to add in the lighting wires for the light panels. After they are all in place I can then make sure everything is squared up and then I can add the vertical detail pieces on the inside and the outsides of the frames. Once I get this done I can actually mount the Refit Enterprise into it's final resting place inside the Drydock. I really hope I can get to that part very soon! I've been looking forward to that very much!
Well, thanks for being patient on this build. I really needed the break last month. Hang in there. More is on it's way! See you next month!
Mark
http://www.NemVia.com
September Updates 2014
Now that I have the majority of all of the details and pieces cast and for the most part painted, I have been able to assemble a lot of these individual pieces together and even start with the lighting process.
This month I received all of the rest of my dry transfers to add all of the letters and numbers to the backs of all of the light panels. They are now complete! After that I started assembling the power nodules to the light panels and then the tanks to the power nodules. I also started adding some mounting nuts for the tension rods on the light panels. I needed to redo them because the originals were not large enough for what I needed. So I had to add 8 of these nuts to each of the panels then later add 10 of these nuts to each of the panel frames. These are now completed.
Any of the missing anchor cones have now been put in place, then I finished putting the horizontal detail pieces then painted all of the details "Rust". This prepared all of these pieces for the next important step of lighting and wiring the panel frames and panel lights.
I have also added the box insert pieces to the overhead modules and cemented them in place. Next was the part that I've been wanting to get to for a very long time. The wiring of the light panels. For my 1/350 scale Drydock I used copper telephone wire and lots of LEDs. It was really a wiring nightmare because of how many connections were needed and later when the model was moved around or slightly shifted some of the panels would go out and then I'd have to find out were the break in the line was and re-solder everything until it worked properly. For this model which is about 1/260 scale, the pieces are a lot larger and easier to work with but I did not want to use LED's because of all of the soldering needed, so I'm, using a new technology for the panels which is becoming very popular for lighted models called EL Wire. This wire can be fed through all of the tubes, be looped around the spurs inside of the panels and then fed through to the next panels and so forth. The LEDs took several days to wire in. The EL wire took me less than 3 hours for one side of light panels.
After I threaded all of the EL Wire through I was then able to connect all of the panel frames together then put on the Vertical detail pieces on the insides of the panel frames. Right now I'm working on the outside of the Starboard frames and adding the Vertical detail strips on there as well.
I'm now beginning the work on the Port side frames and lighting work. After I get this part detailed and wired I will be adding all of the Light Panel Graphics and Front parts of the Light panels. I should also be able to get one of the Enterprise models mounted inside the dock if all goes well. There's still a lot of work to get done but it's getting closer to being finished.
My target date for finishing this is about the end of October-November. But, we'll see. There are 24 New pics in the September updates page. Enjoy!
That's all for this month's update! See you in October!
Mark
All i can say is WOW Mark, some very nice detailed work going on here bud. Can't wait for October.
Have fun, John
Hi John! Thanks for your reply! Well, here's what I have for October...
October Updates 2014
September has been another busy month for drydock building. I was able to spend a lot of time on the Light Panel frame fronts. I had to cut out all of the plexi-glass pieces to use as clear windows and a 3rd piece of plexi for the graphic decals. For each light panel there are 2 pieces of plexi. That makes 112 pieces for each of the panels. The plexi was then cemented in place. I then had to make all of the decals which amounted to the same number of pieces. There are what I'm calling left and right side decals for each piece. There's a slight variance between each of the decals, so I had to make sure they were all put on the appropriate sides.
I've also spent a great deal of time making the turnbuckle anchors and tension rods. One of my clients requested that this detail be physically bolted to the panels and the frames. So here's how the work load pans out for this month. There are 504 tension rods needed for each drydock. These rods connect from the light panel to the panel frames. I am using styrene rods because they are very light weight. I'm spraying all of these rods "Rust" before I cut them to size. This way there will only be a minimum of touch-up work to do. On each end of these rods will be an anchor with a loop on the end of it. (See pics of this process in the October updates page) There are 2 of these anchors on each of these rods so I need to make 1008 of these. 336 of these anchors will be for the center tiers of the light panel frames. The remaining 672 have to be made with the end loops on a slight angle because of the way the top and bottom tiers are of the panel frames are curved. As of this posting I have the 336 anchor loops finished and will be working on the rest later in the week. The hard part is keeping track of how many of these have been done. The other dock will have just the sleeve part of the anchor loop on them so it will look more like the filming miniature version. Later when I start adding the rods to the model I will be able to touch up the unpainted surfaces.
In other areas... because of how repetitive some of this work is it's nice to break off and work on something else for a while. For the last year and a half I've been contemplating on how I was going to build the work light arrays. On my 1/350 version I had no idea of how I was going to tackle this because of the complexity of these lights. In the end I wound up taking a piece of cardboard that had a mirror like surface on it. I cut it into a hexagon shape, then etched a lot of line into it and drilled holes for where the lights were supposed to be. I then back-lit this piece with 3 LEDs to make the lighting effect. Although I've hear some good suggestions of how and what to use for this array, such as a florescent light cover cut into a hexagon shape, it just did not work out for the scale I needed to build these arrays in. I have found some pictures of these light array panels and they were originally used in the unused TV series version of ST:phase II drydock as the side panel lights. They have a very complex configuration and I wanted to at least in some way be able to come as close as I could to getting these as accurate as possible. I stumbled on the simplest of solutions. At my local Hobby Lobby I came across a section that has all kinds of beads, glitter and most importantly of all Sequins. They were in various colors and I happened to notice that the silver ones had a reflective quality as that of mirrors or reflectors that are used in lamps and/or flash lights. JACKPOT! They had 3 or 4 different sizes, so I bought a couple of small bags. I notices that even though they are punched out into round shapes, the center of each sequins had a hexagon shape to it. So I lined up 60 sequins of 2 different sizes of each kind of sequins then measured out the overall size of both of them and decided I had a close match for the work light arrays. When lined up properly with the edges of the hexagon they reflect light similar to what is seen in ST:TMP. So I built 4 of these panels 2 for each of the docks.
I cut out a hexagon shape made from sheet styrene, sprayed them FLAT BLACK, then carefully cemented one sequins at a time until all 60 were lined up and in there proper places. Next I drilled out all 60 centers of the sequins so that one LED could fit into each of the holes. It looks great so far and I can't wait to wire them up and do a lighting test.
For the last part of my update: Since I was able to add the Starboard side of the light panels to the overhead modules I wanted to see how one of the Enterprise models looked inside of the dock so I snapped a few pics and put them into this month's update. There are 24 new pics on the "October Updates 2014" page on my site!Hope you like them. More updates coming next month! See you then! Have a great month!
Mark
November Updates 2014
Hey Everyone!
I have some glitches to deal with on my website this month.
For some reason I'm having trouble uploading photos to my site so I'm setting up the photos to be in the Forum thread until I get things up and running again.
In this month's update I've been working on the part of this model that I've been dreading, but need to complete. The assembly of all of the tension rods with turnbuckle anchors and nuts and bolts. There are 9 pieces per tension rod and there are 2,268 pieces that need to be put together on just the Starboard side of the dock alone. Each piece has to be cemented in place and aligned to each of the panel frames and light panels. Rather than just drilling holes into the Light panels and panel frames and running the tension rods through each of the holes and cementing them in place as I did with the 1/1350 scale PLE Dock My client has requested that the bolts on each of these connection be visible to give greater depth of scale to the final model. Detailing is very important to my client so this once again will slow down the completion of the Drydock. There is one shot of this detail that was visible in ST:TMP when the Enterprise was leaving the dock and the little dude in the space suit was waving good-bye to the ship. I now need to touch up all of the ends of these rods with Rust paint which will blend everything together. The pics show how this detail looks.
Another setback is the light panel lighting effects. After putting some reflective paper into the panels to defuse the light I discovered that this lighting effect would not work at all because you can see the EL wire behind the defusing paper. Bummer. I had to remove all of the EL wire and put in LEDs as I did with the 1/350 scale dock. So I'm now adding reflective tape to the backs of the inside of each light panel and will then have to hard-wire all of the LEDs in place. Not a very easy task at this point at least not with the Starboard side panels. Well, live and learn. We'll see how far I can get with this within the next month or so. December is a very bad month for me to work on this project so there may be very little for the January update to show. But, enjoy the pics. I will try to have them set up on photobucket for now.
That's it for now.
See you in a month.
Mark
