Char,put plenty of formers etc into that long fuselage,get hold of one of those carpet fitters tools that has multi prongs that push out when you place it into the fuselage,draw around the shape onto thick Plastikard and scribe around with a sharp knife or better still an Olfa Cutter ( craft shops ),then snap the Plastikard at right angles finishing off with a sanding block,you could even use balsa wood internal formers,to use these apply balsa cement to the wood and polystyrene cement for the plastic,when joined together the two cements fuse together.
When you build the wings put spars in them to stop them drooping too much,see my tutorial on how to fix them in place.
I look forward to seeing this model as it goes along,Vac forms are real fun to build if not slower than conventional kits,but who cares as long as the end result is there,so plenty of pictures Char !
