Just used Stynylrez for the first time. And ....................... I will never use another primer. A first class product. Had to increase my air pressure quite high but a lovely result.
Patrick, I was spraying with a. 4 needle and needed to ramp my pressure up to nearly 40 psi. I may try it with just a tad of thinner next time.Having used this unpronounceable stuff over the weekend, I've got to agree that's it's very good.
I found a pressure of about 30 PSI was best for me. The aerosol primers are now history!
Patrick, just for info I was using my Badger 105 but seem to think that my compressor wasn't the best as it doesn't have a tank and at that pressure initially starts off fine but the air flow rate and pressure very quickly drop.Alan, I added a few drops of W & N flow enhancer on my 2nd try which helped a lot. I'm using a 0.3 needle atm.
I've got a H & S Infinity 2 in 1 coming, so I'll see if the 0.4 nozzle/needle makes a difference.
