Good afternoon dearly beloved.:smiling3:
The painting has gone ok, but having seen a video on Utube this morning where multiple coloured primers were used I think I have some way to go.
All ways see these things too late, but here we are.
Just sprayed in green primer 4BO , al least it came out well , just a spot of Vallejo flow improver has stopped all the dry tip problems, just don't over do it .
Moving on I sprayed the top coat of 4BO , didn't bother with any high lights purley because of the impending Snow Camo. Steve this is the way forward , one colour. :surprised::smiling3:
Had some fun of course fitting those tracks, they were quite stiff from my enthusiastic gluing ! fitted them in the end, not spot on around the front or rear but half of it will not be seen.
Ending up like this.
:crying:
Ok you can see the bottom join, no way was I going to be able to fit a piece of .4 mm wire at that distance, so glue it was. :disappointed:
Bit of a sag , but they didn't fall apart like they had in the painting stage, hence the use of the Ca.
The internal detail is pleasing, used the Brass shells I got, using the kit ones for empty cases.
Having had some advice from the forum earlier. :thumb2::thumb2::thumb2: thank you. I set too and did the snow camo.
One pot of snow camo .
used these brushes .
Wanted to show the brush marks , instead of a blanket cover. Don't know if to do any more, here are some more shots. please say what you think.I still have to wait for it to dry fully before applying a soft brush wetted to remove the camo from the unit markings.
Comments more than welcome, as I said should I do any more coats ?
John.
:crying:
John.
