Whilst still boasting my L-plates in the paint department I've started another build before I'm ready to do the final paint on my Jagdpanther. (actually, I've started more than one more tank apart from the Jagdpanther to be honest...)
I love building these tank models and although I'm not yet ready to begin the final coats - I can build more tanks whilst learning the necessary skills!
One of the tanks i just bought was the Jagdpanzer Elefant - with zimmerit vinyl stickers. I shouldn't really say "stickers" since what I got was one solid sheet of emulated zimmerit where you have to cut all the pieces our yourself, and here's my critique...
There are like a million little holes in all the pieces you have to cut out and this proved to be more than just a challenge!
I really don't mind having to assemble a ton of tiny pieces into a tank - that's the hobby imho - but not using a cheap laser cutter to pre-cut all little zimmerit pieces - and especially all the tiny holes - is terrible if you ask me!
I might still be a learner but I can spot something that hasn't been fully thought through, and the Tamiya zimmerit sheet should be renamed from "sheet" to "shit" if you ask me! (excuse the language but good it ain't.)
A few tiny hole punches would've been handy but there were none in my toolbox. I resorted to grab a few tiny FR4 drills (for drilling circuit boards) and manually, by hand, "drilling" out each little hole in the zimmerit pieces. It left jagged edges that needed careful trimming with a sharp nail cutter. I think I got away with it but it took two days... sigh.
I was careful handling both the tanks surfaces, and the zimmerit, in order for it to stick. Careful trimming was also needed on a few places, but it's all there now but I do wonder how long this will last? I will probably be a bit upset if this tank turns out ok and 6 months later the zimmerit starts peeling off...
I might use a tiny bit CA glue along the edges just in case, but I'd prefer not to.
I should've researched the subject prior to buying the zimmerit sheet but I didn't expect it to be so basic?!
There's plenty of room for improvement here Tamiya! A laser cutter costs peanuts today and I'd be really surprised if you haven't got one or two already?...
I will try to blend in the zimmerit where the fit isn't perfect either with putty, or a soldering iron. More on this later...
The kit itself is nice and I like the level of detail! I'd say it's an easy kit but some dexterity is required for some of the smaller parts, but a pretty fast kit to build. (if you don't count the zimmerit...)
One thing did raise a question regarding the kit. The tank is designed with "working" suspension and wheels, but comes with separate track links to be assembled in a rigid fashion - not like all the other Tamiya kits I've got with soft working tracks?
Why design a model to have more "working" parts than usual and then not supply working tracks? Not even the cheapo soft one they usually supply? Beats me.
I have a soft spot for tank destroyers and they are probably going to be in majority in my planned German lineup.
To be continued...
To be continued...
