Tamiya US 6x6 Fuel Truck 1/48
Hello
This isn't much of a build thread because I already mostly built it since it goes together quickly but here it is anyway:
To complement the truck and the diorama that I will put it on, I got the tamiya jerry can kit
The chassis was easy to assemble, I airbrush it olive drab then I picked out the details with flat black
The cockpit did not have many details but you won't see much of it anyway in the finished model
Unfortunately, there is no "engine". I was hoping that the hood could be opened
Once assembled, I airbrushed the front of the truck with black to create a sort of pre-shading
The pre-shading seems to have worked after airbrushing a thin coat of olive drabView attachment 104803
Cockpit glued onto the chassis and a bit of dry brushing with chrome silver to create a worn look
The wheels were a bit of a pain and took a good couple hours to paint
But once finished and glued into place, they looked really cool
To create the fuel hose, metal wire is inserted into a rubber tube so that later you can adjust its position easily.
Once again, pre-shading
Assembling the fuel cistern
the roof and a few bits and pieces glued into place
Sidewalls installed and everything else painted. Unfortunately, most of the detail inside the hose compartment won't be seen because of a closed hatch.
Too much weathering?
So far, so good...
I did not want to airbrush a clear coat because when I tried it on the chassis, it made it too dark and softened a lot of the detail. Also, it is hard to get the gloss back to a nice flat finished later on. For this reason, I decided to apply decals straight onto the paint. As you can see, it did't work because the paint would get stained by the water and change its tone. I decided that until I knew of a solution to this, I will not apply any more decals. Can anyone help?
I think the bottom turned out well
When placed in the P-47 diorama, obvious flaws such as a lack of decals are not very noticeable.
The build is not finished yet, I need to make the figures and I will try to somehow sort out the decals, maybe rub on transfers?
I will be away for about a month so I won't be able to build the great scale figures that come with this kit but it will be the first thing I do when I come back.
See you next time
Looks good & a nice view of the transmission drives. A job well done.
John.
Hello every one, got back from my holiday with renewed enthusiasm to continue scale modelling! I order to complete my P-47 diorama, I assembled and painted three of the figures included in the refuelling truck but unfortunately I lost one of their heads so now its down to two.
The clothes were painted khaki, the helmet olive drab, booths flat black and the skin in Tamiya flesh
I love how tamiya included a rubber refuelling line, it adds realism and is really easy to adjust.
Along with the figures, I painted some of the miscellaneous parts from the Tamiya WW2 jerry can and supplies set and added them to the scene.
Is a shame that the driver won't be seen once I put the doors back on.
Can't wait to start my next scale model, a Tamiya A-1 skyraider in 1/48!
See you next time
Nice work, glad you found the enthusiasm to finish it. Look forward to the skyraider
