Testor/Revell Color Conversion Question
Greetings,
I'm new to modelling, but I'm excited about getting started. I teach Social Studies and I think models in the classroom could be pretty cool. That aside, I have a list of enamel paint colors in my Revell instructions for my Spitfire Mark II airplane model and one of the colors is "Blue Green." I did some paint conversion chart hunting and according to what I've found so far neither Revell nor Testors makes a "Blue Green" color of enamel paint. Has anyone else had this problem? If so, how can I figure out what color Testors paint I should use to be the equivalent of Revell's (non-existent) Blue Green?
Thanks for your time - and an apology beforehand if I missed something obvious that makes you think, "noob" :)
Could you let us know where the blue-green paint is to be used (which part)?
What number is on the Revell instructions? It will be easier to convert it from that and probably tell you which bit it needs to go on
Hi Ereden and welcome to the forum.
I've just pulled up the instructions for your Spit and from what I have seen the "Blue-Green" refered to is interior green for the cockpit which I found on here - Ultimate Model Paint Conversion Chart - Paint4models.com.
Revell don't seem to do this colour but Testors do, if i'm right, and the Testor number is 2062.
Hope this helps.
Good luck with your build and post some pictures when you're done so we can see how it turned out please.
Regards,
Tony.
Thanks guys! I appreciate the help...wow, Tony, that database has a lot of great stuff in it. I found that database last night, guess I didn't use the right criteria in my search - I'm still not sure what all those columns mean. lol :)
Glad I could help.
If it's any help, when I first used the paint conversion chart, I just clicked the buttons to see what happened til I got the hang of it. It can be a great help when looking for kit stated colour from another paint range.
Tony.
That's a great system,
As Tony says, just mess around til you find something.
How I did it was: - click all the brands you know you can get hold of, so they're ticked, including British Standard and FS, then type something like "Gunship Gray" or whatever. Then untick the ones you don't use, leaving say Tamiya, Testor, FS numbers (for cross referencing).
THEN
If one brand has an FS equivalent, you can then re-search for the FS number and see if any brands match.
A bit long winded but I hope this helps
Stuart
\ said:
That's a great system,As Tony says, just mess around til you find something.
THEN
Stuart
This doesn't work for me. I clicked on the address given by mossipilot but the screen was blank. I then downloaded the PDf version, but (not unexpectedly with a PDF) clicking the column heading (as you recommend) simply selects the text of that heading.
Hi Steve, I've had this problem too. I wondered if it was a problem with my browser, I use firefox, but I find if I reload/refresh the page a few times the page comes up. I'm going to try it on internet explorer see if that any better.
I'll let you know.
Tony.
\ said:
Yes, that worked better, came up first try.Tony.
Yes! Got it. Thanks. What a useful resource. Is it up to date, do you think?
As far as I've been able to test it, against Vallejo and humbrol, which are paints I can get the easiest, it's correct.
Tony.
