The Apocalypse Is Here!
yambam26
Hi all,
I have been building this Diorama in between other projects and just any spare time, It all started of with a H0 scale Trackside Western style carriage which when i opened it i found it to be warped/heat damaged
I then just kept going with painting techniques salting,dry brushing etc.
I went on to just mount the carriage to a base and well what can i say i started this as a out of the box build think ill keep it simple, the mind then took over and i went down the Zombie route. I found some HO scale zombies on ebay which are not the best but give the effect of what i was after.
Here's what i come up with.
The last two have a little bit of photoshop filter on them for effect :)
Hope you guys like it,
Cheers,Ben
Good job!!! Try to make some pictures using just some candles in a dark room. It will be great!
Great work Ben you'll soon be giving Monica a run for her money with these diorama's
Aha Ian im quite a way from Monicas builds!
My trouble is now that my display cabinet is filling up quick now.
Cheers,Ben
