Throttle setting
Hi everyone,. I'm intending buying a 2.4Ghz system to use in one of my model boats.....however I would also like to use the tx for a beginners aircraft.  The skyfly i6 tx is the one I have in mind but I could do with some advice on throttle settings....... the left hand stick for ships is set centrally so that either forward or reverse throttle can be used..but with aircraft the stick is set up at the lowest position as there is no requirement for a reverse signal.  Can the throttle setting be easily changed to suit whichever model type is being used, in other words will the tx remember and react to the initial setup of the models original esc setting? When sea and air models used dedicated frequencies this changeover didn't crop up...can someone advise please.  Thank you,  Ian.
