Under Watchful Eyes
Steve Brodie
Story;
A warrior patrol stops at a road block and a boy with his grandpa approaches, a British Soldier looks on from behind the barricade whilst the boy walks towards the soldier with a flower in his hand, the crew of the Warrior are keeping an eye on what’s going on from their lofty perch being in communication with the rest of the soldiers in the back of the warrior. The grandpa is also keeping an eye on his grandson and the soldier and shouts across “ahlan as-salaam ‘alaykum” peace be with you my friend.
Jersey Barriers
These (4 in total) have been made using the mould that comes in the Meng barrier set. They have been distressed with a sharp knife and one of them has been bounced around with a small burr head in a mini drill, I will most likely do the same to the rest of them. Floral craft wire has been used to make the lifting handles, (wire bent over a paintbrush shaft), made slightly different for each one.
Ok, so being in this kind of situation in real life more than once, I will follow this build.
Cheers Richi
Cheers Richi
No pressure then :-). Hopefully I get it right
i like the sounds of this,and will be keeping a watchful eye my shelf, :D
do like the looks of the barrier ,Steve and what your done makes it look real like, ;)
I used them in my zombie Dio,as well,
Heard of Jersey Wonders, Jersey Potatoes and Jersey Cows as I live among them (slight distance between ?) :D But not Jersey Barriers.
Tut, Tut - http://en.wikipedia.org/wiki/Jersey_barrier ;) ;)
In that case Steve they should be known as New Jersey Barriers. We are the original Jersey. All the others are imposters. :D
there turned out so well Steve,real like that look with the cracked paint on the bottom on the middle one, ;)
