As requested, here's a quick review of Uschi van Der Rosten's metal polishing powder, Iron. They also have 2 other types, Chrome and Steel. The pigment powder comes in a 25mm plastic bottle with a screw on cap. A comparison with a paint bottle,
It isn't very big, but should last for years as one doesn't use too much for the job. The pigment powder looks like this,
If you look closely, you can see the metallic particles in it. I did a simple test using a piece of sprue. I painted two strips of the Vallejo aluminum Metal Colors I got yesterday. On the left is 717 Dull Aluminum and, on the right, is 716 Semi Matt Aluminum,
I let them dry for over an hour and then grabbed a normal Q-tip. I dipped it lightly into the powder and applied it to the paint. I scrubbed it around and blew off the excess. I rubbed a little too hard on one spot on the left strip, and this was the results,
My pic is not the best, but it does leave a nice dark metallic shine on the 2 aluminum colors. Then I tried it on the motor block from my Halberstadt wing thingy. The cylinders were painted with AK's 719 satin black. I rubbed it on the 2 cylinders on the left,
I think the difference is obvious when you look at it. All in all, this is an interesting product and will have many uses in our hobby. They are a bit pricey, costing about € 11-12 a bottle, but you use very little to get the results. Therefore, a bottle would probably last a good 10-15 years. It's non-toxic too...
John stocks them in his shop and they are also sold under the Das Werk label too. Hope this helps a bit, so give them a try!!!...
Allen
PS, this test also made my decision as to which aluminum color to use for my motor...
Allen
