Hi all,
I've come to the conclusion that I like to prime my kits prior to airbrushing and have until recently used rattle cans from Halfords or the more refined Tamiya Fine primer. The thing I don't like about rattle cans is the uncontrollable nature of their spray, it's usually all or nothing with lots of overspray.
So I decided to give Vallejo Air Primer a go through my airbrush and to be honest I'm very happy with the results. Even though this product is designed for airbrushing straight from the bottle I do find it's very thick and for me it needs a 50/50 mix with Vallejo thinner to be able to spray at about 15-20 psi.
I still need to be quite quick as it dries on the needle within 5-10 seconds if not used and is a headache to keep taking the nozzle off the airbrush to clean the needle (it's a Badger 200 single action).
Now the problem is when it comes to cleaning it seems to take half a dozen cups of strong airbrush cleaner or Vallejo's own cleaner to get anywhere near clean. In fact the few times I've used it I end up stripping the airbrush to clean off the needle, nozzle and cup seperately! Am I missing the obvious or is primer through an airbrush a little trickier to use and clean than paint acrylics?
Atb,
Colin.
Atb,
Colin.
