Vallejo and Tamiya acrylics
Just a quick question before I spray a model.
I plan to lay a base colour down in Tamiya acrylics, varnish, and then add the camo with Vallejo acrylics. Will this cause any nasty effects?
Cheers :)
Probably the best way Alex to find out is to experiment before letting loose.
Though that does not give a long term confirmation.
I do believe that Tamiya & Vallejo have different dryers so what difference that makes not sure. I would have thought a good drying time to make sure the under coat is really cured is essential.
Not used Tamiya & would be interested to hear results.
I don't think it would Alex, as I've done the same thing without a sealing coat of varnish & it was fine.
I'd perhaps leave a tad more time between the coats to let the paint cure, but that might be undue caution!
Patrick
Thanks Laurie and Patrick, I'll do a tester before hand and see what happens.
