Wall filler and Klear
AlanG
I'm designing a dio at the moment and wanted to use wall filler for something. Was just wondering if i can use Klear (Future) to seal the filler after it has dried?
Anyone know?
cannot see why not. May take a few coats though as plaster soaks everything up like a very thirsty thing. I would use watered down, not too thin, PVA as it gives a great surface to then stick the scatter material to. However, Klear would be best for the finished item but remember it is glossy so a matt spray would be required.
Hi flounder , Graham has made some good points , being an ex-decorator filler can be a pain to seal , anything water based will just get sucked in leaving it patchy no matter how many coats you give it , if it was me I would give it 2 coats of oil based or enamel paint , when in the trade we used to cover filler with oil based undercoat to get a top finnish .
Hope this helps
Richy.
Fen that's your answer to everything today! Good advice tho. You too Richy, you the man.
Cheers for the info Graham. I'm not actually going to be sticking scatter to it and i need the surface to look glossy hence why i asked about klear. But if the pva gives a glossy finish then that might work.
Can pva be painted over with enamels/acrylics?
Not only can PVA be painted over but it can have acrylic paint mixed into it to colour it.
