John if you use with Vallejo acrylics the flow improver you will not have this problem.\ said:the only ones I'd avoid is Vallejo acrylic ones, purely on the basis that they dry far too quickly and if you miss an overspill (easily done on a complex model) you are pretty much stuck with it!
Laurie I'm confused! What does airbrushing have to do with applying a wash? I'd always use a brush, but is this some new technique?\ said:Just thought John you are using hand brushing which is very different to airbrushing.
For instance I would not have a coat wet enough with a wash to pool whereas with
hand brushing I would think, form my architectural rendering with brush, you have
a wetter application.
My experience above is based on Airbrushing entirely.
You airbrush washes on??\ said:Just thought John you are using hand brushing which is very different to airbrushing.
That's what's got me confused! Perhaps I've misunderstood what Laurie is saying ....\ said:You airbrush washes on??
\ said:Laurie I'm confused! What does airbrushing have to do with applying a wash? I'd always use a brush, but is this some new technique?
From the Vallejo site\ said:You airbrush washes on??
