Weathering kits which one?
Hi all just placing my first order here. Never used weathering (never even heard of it before I came on here) just wondered what is the best kit to start with was looking a Vallejo, what do you think.
I've tried a few weathering products and there's not much difference ones I use are Vallejo for washes and humbrol for pigments but you can make your own , all a wash is is a weakened down paint it does the same job :) weathering pigments like powders are better though than just simple dry brushing and mig are one of the best
If I was you I'd go for a humbrol pigment to start as it's a bit cheaper and see how you go with it :)
I use various methods Ken. Filters, pigments, enamel paint diluted with white-spirit, oils-again diluted, pastels, felt pens, pencil-great for metallic edging.
Si:)
Ken I started with Flory but found that messy probably me.
Then got half a dozen Vallejo which I found much better. Probably as I found them more controllable as they are based on water and an additive presumably Vallejo thinners. Flory being totally water based I found that the capillary action was a nuisance.
Also found the Tamiya weathering Pallets with three tablets inside and a foam brush great for effects exhaust gun marks etc.
Also have pastels (chalk not wax) a variety of felt tipped pans and coloured pencils.
Next needed is an artistic ability only bought with time and experience, as I am finding, not an easy commodity to acquire.
Ken, I use oil paints for my washes & artists pastels for dust / rust effects.
The ready-made stuff is all well & good, except that you end up with lots of pots and an empty wallet!
Rymans do nice oils and pastels at about £4 each.
Thanks for all the info. So I shall look at filters and not pigments as I can dilute paint myself. And I do have quite a few pastels oil and chalk based, never thought of felt tip pens though, what are they used for?
You can use felt pens for rusting or streaks, also a glass-fibre is great at scratching out paint in areas or decals etc-if you use it lightly.
Si:)
will have to get a set of them will cheap ones do or should i buy decent quality ones.
Definite quality pens. You will get different thickness's of the felt nib. Good ones keep the felt shape and size. Cheaper ones I have found fail on those scores.
There are permanent and non permanent. Best I think to get a couple of black and see if they are for you. Like a lot of model making things some you only use in a blue moon. Then all of a sudden they are used all the time.
I use Faber Castell PITT artist pen indian ink and permanent but there are a host of others.
Like many modellers here, I produce my own washes and filters with oils and others.
Anyway, I always paint with Vallejo...but if we are talking about weathering, they are not so good (for me), the best are AK interactive/Ammo so far...
But remember, is only an opinion :P you should play and try new things until you found your own style ;)
real cannot add more to what the lads have said, as i make my owe,washer,and filters as well, and much the same way as how its been said,
just try ,diffidence methods to find one that suits your style of paining,, ;)
one good trick with oils is put a little of each color that you are going to use out on a thickish bit of cardboard and that will pull out the oil,
and then just place a small dot hear and there were you wont them then come back and paint it down with some white spirits, to blend them in,
