Does anyone know how to weigh down the front of a 1/72 Me 262 even though the model has been put together and painted?
Thanks
Blair
Blair
That's a great idea!\ said:Probably no recess in through th cockpit is there? Perhaps drilling a hole in the inside of the front undercarriage stow area, and dropping some weight through the hole, holding the plane nose down and spraying a little expanding foam in to hold the weight in place, then filling and carefully touching up the hole
Other than im outta ideas, anyone else?
I've heard somebody talking about using liquid gravity before, maybe it was you. I can't remember.\ said:I use Deluxe Materials Liquid Gravity to weigh down the nose of aircraft (before I button them up!), you may find it easier to retro fit in your situation.
Fit or install something after construction.\ said:I've heard somebody talking about using liquid gravity before, maybe it was you. I can't remember.![]()
Sorry but what does retro fit mean?
\ said:Fit or install something after construction.
Alright thanks\ said:http://www.thefreedictionary.com/retrofit
Good recovery and a lesson learned perhaps.\ said:Hi all, I tried using 4 or 5 small strips of a 4mm diameter brass rod to weigh down the nose, so it's now sorted![]()
Thank you everyone for your help
Blair
Thank you and definitely a lesson learned\ said:Good recovery and a lesson learned perhaps.
