I'm converting a Veron Fokker Dviii from Gas to Electric. I am puttng an AXI engine into it' date=' and this engine needs to be mounted through a firewall. The cowling on the model is such that I am not really going to be able to give the down right orientation to the engine. I am wondering about putting some weight in the right wing tip. Good idea, bad idea? Would this at least help in the pull to the left during flight?[/quote']Don't like the idea myself - any imbalance in an airframe is a recipe for problems - potential disaster with a heavy wing tip.
Wouldn't it be possible to make the hole in the firewall offset to give the required side and downthrust?
From what I remember of the shape of the front of this plane, it shouldn't be difficult to do this for an electric power plant. Electric motors are far less bulky than glows and the necessary offset thrust can be accommodated for those engines.
Having said that, I have no direct experience and am just making my observations and drawing conclusions from what I have read in magazines and on news groups.
As far as I know, no full size aircraft has any down or side thrust. Torque induced turns are usually corrected for by judicious use of control surface deflections.
Malcolm
