Weltkrieg 11 deutsche Werkstatt
Usually I have a name or an title for a dio before I start but with this one it is different. I am going to be using the famo on it with some other bits and bobs. I have seen them modeled with Tigers, Nashorns and a few other tanks but not as yet seen one with a Bergepanther.
So that is what I am doing it with from what I have read these Famo's were used by panzer repair units and the Bergepanther will fit in nicely.
I am not going to do separate build threads for each element as that can get hard to keep track of. Instead the build threads will be part of the dio build in it's entirety.
First up on the bench will be the Revell Bergepanther (Sdk.kfz. 179
This looks a better kit than the old Bergepanther I had, interesting.......
I didn't know the Famo trailer could carry something this big, I always thought it maxed out at the Panzer IV. You live and learn :)
Nice one Terry, looking to see what you do buddy;)
I like the look of this it will be good to see were your taking it will be watching it with interest,when they towed the tigers did'nt they use two or even three of the 18 ton half-tracks pulling together just to move the beasts.
Interesting,Terry,it has no gun lol,wears the gun, :P
I will be watching as well,have my seat ready,looks like of this
and what you will do, ;)
thanks Graham
Kevin on having a better look on the net it would seem you are right the panther is 10 tonne heavier than the tiger so would need more than one Famo to pull it along. So I have another idea that still uses both but in a different way.
looking good with this one Terry,nice work on the wheels, :)
the PE,dose look good,and always so fiddly as well,good luck with it, ;)
Thanks Monica glad your liking it so far.
well done with the wheels,looks great the camo on them, ;)
as for the links,
I always do put a dab of glue on each one,as they do fall apart,
what I do so you keep them straight is tape a ruler on a board,for a straight edge,then you have
away of them not slipping away,once you sit down and just keep at them it dose not take to long,:rolleyes:
as for the links,
do you paint before you start or when you have finished Monica?
Hold on a second, do you mean to say you have a B.P. plus a Famo with trailer? Well I have a name for your Dio......"Jim's Jealous-Jealous-Jealous!!!"
I will be watching you lucky dog!...........Cheers.....Jim:)
I was a lucky boy at Christmas Jim.
with the tracks I,will paint when done,but not on,and do the weathering at the same time as the rest,so it all blends in o_O
and to get the bend in them ,I wait till you know the glue has hold,but not set fully,
and I tend to run some making tape on the outside so as you do bend them,it dose
help to hold,until fully set, ;)
Cheers Monica I have already used Vallejo track primer on them before reading this. The tracks for this build are giving me a few headaches I can get one side to lock in but when I try to get the other ones to go it pops out. Needless to say I have not got a lot done today.
