Wermacht uniform belts and straps?
takeslousyphotos
Hi all,
A question........ I probably should know but I honestly don't. What colour were the Wermacht uniform belts and straps? Black or Brown ?..............and were officers and enlisted the same colour?
Thanks.
I always do in a dark gray with black outline, so that they will pop out some what, ;)
but have seen them in browns as well,
this may help as well,
https://www.google.com.au/search?q=Wehrmacht+uniform+belts+and+straps%3F&biw=1906&bih=944&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjNhseopMjKAhWD46YKHRylAFEQ_AUIBigB
https://www.google.com.au/search?q=Wehrmacht+uniform+belts+and+straps?&biw=1906&bih=944&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjNhseopMjKAhWD46YKHRylAFEQ_AUIBigB
Thanks Monica. Much appreciated. I think Black is the way forward. Outlining is probably a bit beyond me as these little fellas are small enough and I'm a beginner with figures......... To be honest I wouldn't have bothered with them. But the 251 I'm building (albeit slowly) really does need them.
glad to help, ;)
as you mostly only see there backs,spend more time on that part,
as the figures have great detail,and are nicely out lined,paint there,
uniforms ,then the straps ,in a dark gray/black,and once dry,give
a wash or two,with,black and that will drop to the lowest point,and
pickup as high lite, :)
