What connections do i need?
AlanG
Right this is probably a very stupid question but i am lost.
I presently have a Clarke Pro airbrush set and a Clarke Wiz compressor. I need to put an in-line water trap/pressure regulator in it and i am confused as to what size connections i need from the compressor to the water trap/regulator. I will need to buy a step down for the WT/R as i 'think' it's 3/8 but don't quote me.
Hi,
You have a 1/8 bsp connection at the end of the carry handle. Not sure if it is male or female, but which ever it is, you will need to convert it to a 1/4 bsp connection as the CAB2P kit has a connection convertor to 1/4 bsp in the kit. Therefore you need either a 1/4 female to 1/8 male or 1/4 male to 1/8 female depending upon the compressor and airbrush connections.
Once you know the connection configuration, have a look on www.airbrushes.com and you will find a suitable water trap and pressure regulator to fit.
Hope this helps.
Regards,
Leslie.
