What to do with this ?
It looks a bit .... plain to me Alan - bushes & trees needed perhaps?
What's the ' fake snow '? Looks like talcum powder!
It's powdered glass mate
I'm thinking as you are trees bushes and might add a plane heading upwards as if it's pulled out of an attack
Could even use some cotton wool on the puma and pull its gun off as if it's been hit
Can't u Ruff up the terain a bit? Holes or dirty n stuff? Maybe some loose army atire like helmets?xx
I would be tempted to do both as wrecks with snow drifts around them, shell holes and snow on top.
Si:)
Do you want it mate ?
It's yours I think to make it look really good would be a challenge for me but I'm sure you could do it with your easy closed :)
\ said:
Do you want it mate ?It's yours I think to make it look really good would be a challenge for me but I'm sure you could do it with your easy closed :)
Nonsense, it's 90% done, just add what you want, some small burnt matchsticks etc for a building sticking out the snow, some snow drifts etc, a bush or two.
Ok mate I did like your wrecks idea and I do have some landscape dead trees that look burnt she'll wholes might be a problem as this is small the base isn't even a4 size but the rest is doable :)
Guess I'm keeping it then
\ said:
Ok mate I did like your wrecks idea and I do have some landscape dead trees that look burnt she'll wholes might be a problem as this is small the base isn't even a4 size but the rest is doable :) Guess I'm keeping it then
Yes, keep it, a small easy dio, not in the way or much work, just enhance it slighlty.
Si:)
\ said:
Powdered glass!! :eek:A tad hazardous maybe?
Only if you eat it , it's used as a cleaning agent and as long as you use a mask and use a sifter it's perfectly safe :)
a lot has been said that i would off ,have the tank coming out of its hiding stop after being shelled,so some bushes and shell hole,with some burnt trees, :rolleyes:
I'll stick with my bicarbonate of soda mate!
