Being from down under, I just checked Wikipedia for White Spirit, it appears that it is totally compatible with enamel paints.
http://en.wikipedia.org/wiki/White_spirit
Following this thru, you come to this page.
http://en.wikipedia.org/wiki/Mineral_spirits
Then this page leads you to this page.
http://en.wikipedia.org/wiki/Turpentine_substitute
Now this last lot is the stuff I use all the time, you can buy this stuff at the local grocers store, if you just mix the enamel with this mineral turpentine 50 / 50, give it a shake, mix, whatever. Then start spraying the gloss enamel and when you reckon you have a good colour coat on the model, empty the colour out of the spray jar, fill it up with neat, plain mineral turps and while the paint is still wet, start spraying on the plain turps, only giving it light dusting coats with this straight turps, one or two coats is required, then put the model under cover ( cardboard box ) to stop any dust from settling on it.
What this does is actually thin down the top of the wet colour paint and draw it out nice and smooth.
You get an excellent gloss finish by doing this, if you just spray on the colour and leave it, you can and will get a faint orange peel look to the finish coat, spray on the plain turps and bingo, mirror type finish.
Give it a go and see what results you can get, you can use whatever you thinned the paint with, as it will then be compatible with the paint.
regards radish
