Quick question as per the title. Ages ago, I started a Tamiya 1/700 waterline Yamato. I have main and secondary armament brass barrels fitted and a wooden deck veneer to go on, on the Yamato, this is two part, and I have a set of railings and other bits (long time since I looked).
Anyway, I have never used a wooden deck before but, thinking it through, I see a few problems. Before fitting the wooden deck, the plasic has to be sprayed so that the sticky through bits are the right colour. But what about the railings? Should I try fitting the railings, spraying the deck and railings before adding the wood veneer?
Not sure if I fit the wood before the railings and if so, what do the railings glue to? Would railings glued to veneer hold?
