Ordered some gloss and satin from John's shop, (first order), the delivery was lightning fast, thankyou very much kind sir.
Just tried my first blast of the gloss on my airfix 1:72 FW190D prior to decaling and oil wash / panel line jiggery pokery.
It thins beautifully with water and I used a bit more than the 15% and sprayed through my siphon brush which I normally use for Klear, at about 20psi, with the gravity feed I suspect it would have sprayed well at about 15psi as with the Tamiya acrylics.
It gave a gloss similar to straight Klear but I only sprayed a couple of thin coats for the decals and wash and will be using the Satin as a topcoat.
It dries nice and quickly too, I was handling the model and applying the oil wash just 25 min after coating and (fingers crossed), all seems well, I'd normally wait overnight if I use Klear but wanted to test the claims of a 15 min drying time as per the bottle label claim.
It's now sitting and will be decaled tomorrow.
So initial impressions of this clear coat is good, and is good value too, about £3 odd per bottle for 100ml
Not sure how glossy you could get this but then in my previous experience acrylic varnish never looks as glossy as Enamel or cellulose / lacquer
Will update when I spray the Satin topcoat.
