After letting the primer really dry overnight - the trainer was sprayed overall dark grey, and the display aircraft had the lower fuselage sprayed white.
I'll let the white harden off overnight, then mask up & spray the red, which could be a tricky business!
The Yak-130 is around the same size as the BAE Hawk, with similar characteristics for performance, albeit with the safety of twin engines.
