Special Hobby 1/48 Martin Maryland.
  • Dave W
    • Jan 2011
    • 4713
    #61
    [ATTACH]85932.IPB[/ATTACH]
    [ATTACH]85933.IPB[/ATTACH]
    [ATTACH]85934.IPB[/ATTACH]
    [ATTACH]85935.IPB[/ATTACH]
    Done a bit more tonight.The props and wheels needed holes drilling out so they would fit on the axles and prop shafts.And there was a fair bit of flash on the undercarriage legs and props that needed cleaning up.On top of the engine cowlings is a large gap where they join the wing.So I've filled it with plastic card.I found some more gaps around the clear parts which I have now filled.Getting close to the painting stage now.Infact, I might get a coat of primer on tomorrow evening.
    • eddiesolo
      • Jul 2013
      • 11193
      #62
      Nice clean work Dave, those engines and cowlings do look spot on.
      Si
        Nice work Dave, she looks ready for the primer coat
        • Dave W
          • Jan 2011
          • 4713
          #64
          [ATTACH]86071.IPB[/ATTACH]
          [ATTACH]86072.IPB[/ATTACH]
          This evening I sprayed the glazing with the interior colour Vallejo chromate green.When this had dried I put a few coats of Alclad white primer on the model.Im pleased with how it's turned out.But will give the model a closer inspection tomorrow.The aircraft I'm modelling was previously a French Air Force aircraft.They were sprayed without a primer coat.So the paint weathered quite badly.Im going to try and replicate this on my model.Havent had much success with chipped paint in the past.But I'm going to have another go.
          • flyjoe180
            • Jan 2012
            • 12664
            • Joe
            • Earth
            #65
            Looks tidy and clean Dave, great work mate.
            • tr1ckey66
              • Mar 2009
              • 3592
              #66
              Hi Dave
              Just caught up with this build again and read through the previous posts. The work so far is excellent and you've made a great job on this short run kit. Best of luck with the chipped paint finish I'm sure you'll pull it off.
              Paul
                Great looking base Dave ,looking forward to seeing the chipping !
                  Mmmm....smooth work Dave
                    Nicely primed. Now looking for the weathering phases.
                    Francesco
                    • Dave W
                      • Jan 2011
                      • 4713
                      #70
                      [ATTACH]86117.IPB[/ATTACH]
                      This particular aircraft suffered a lot of paint flaking.If I try and replicate it I know I will make a mess of it.So I've decided to just do the wing and tail leading edges and the cowl fronts.So tonight I've sprayed some Humbrol enamel silver on these areas.Tomorrow I will apply some salt.Ive done the salt method once before on a Phantom and was pleased with the results.
                      • flyjoe180
                        • Jan 2012
                        • 12664
                        • Joe
                        • Earth
                        #71
                        Dave, you've got this mate, the salt chipping on your F-4 was spot on, this will be no different. How did you find the silver? I recently used a new pot but it looks like Humbrol have 'dulled' their silver down semewhat.
                        • Dave W
                          • Jan 2011
                          • 4713
                          #72
                          I actually used Humbrol steel as the only aluminium I have at the moment is Alclad or Vallejo.I tried spraying other colours over the Vallejo once and it didn't like it.And Alclad requires a gloss black base coat to work properly.Thats why I keep coming back to enamels as I'm my experience they are better for this sort of thing.I saw this aircraft on a Czech model club stand at Scale Model World show a couple of years ago.The man who built it used an 'AK Interactive' product to do the chipping effect.It looked superb and far better than anything I could do.
                          • Dave W
                            • Jan 2011
                            • 4713
                            #73
                            [ATTACH]86154.IPB[/ATTACH]
                            [ATTACH]86155.IPB[/ATTACH]
                            [ATTACH]86156.IPB[/ATTACH]
                            Tonight I applied salt to the leading edges .Ive now left the model in my shed to dry overnight.Tomorrow I will spray the underside colour on.
                            • flyjoe180
                              • Jan 2012
                              • 12664
                              • Joe
                              • Earth
                              #74
                              I must try my Humbrol steel paint, I used traditional silver 11 recently and was rather disappointed.
                              • Dave W
                                • Jan 2011
                                • 4713
                                #75
                                [ATTACH]86230.IPB[/ATTACH]
                                [ATTACH]86231.IPB[/ATTACH]
                                [ATTACH]86232.IPB[/ATTACH]
                                [ATTACH]86233.IPB[/ATTACH]
                                I'm having a lot of trouble deciding which paints to use on this one.Ive looked at lots of pictures and other stuff on the web and still can't find a definitive answer.The kit painting guide is in black and white and a bit confusing.But I've downloaded a colour version from the manufacturers web site.Ive managed to find a French colour chart on the IPMS Stockholm site.But even that's not a lot of help. It appears the colours on the real aircraft varied a lot depending on where they were painted.I've used RLM76 on the undersides.Mainly because I've got two tins of the stuff!.Upper surface brown shades I've seen vary from chocolate brown to hull red.I know the grey colour is a blue grey shade.Ive two to choose from.And I've decided to use Humbrol 30 for the green.Ive also changed my mind about the chipping and have decided to do more of it.So I've sprayed some more Humbrol steel on the model and will put some more salt on tomorrow.
