North American RAF Mustang III 1/48 Tamiya
    Polux ,Patrick,Terry,Derek,Joe and Ian thanks very much for the positive comments.
    I had the Decal session I would'nt wish on anyone yesterday. The a/m Techmond decals must have been on the shelf for a long time as they were very brittle and would fall apart with just a little prodding. Also the decal solvent took several applications and even then was not much help. I lost a section of the lettering codes and had to cut up the others on the sheet and patch the areas that dissentegrated. The bombs on the nose literally seperated into individual little single bombs and went willy nilly,I managed to save most of them and get them lined back up. The rondels are a mix of the Tamiya and at least these settled in decent. Very frustrating but it still came out passable. I got the wash down and its ready for some weathering now.
    I made the band on the fuse too wide by 1mm or so and it threw the rest of the codes too far forward,totally my mistake I should have been more careful measuring and masking. Looking at it now unmasked with the decals down the white stripes are too wide as well,do'nt know were my head was!
    Before I start weathering been taking a close look at the photos and to me it appears that the airframe has had a good cleaning up. I'm geussing for the photo session? There is really no exhaust soot at all just a slight 'stain' were it looks like it was scrubbed down pretty good. The side of the fuse under the Cockpit has some rather distinctive scuffing,staining and wear though. Wondering how much the underside got cleaned if at all,as a former Aircraft Mechanic that was a dreaded task in the best of conditions. I'm thinking since I'm posing it with the pilot in the Aircraft if I should add some slight exhaust stains and some subtle dirt and streaking as if returning from a mission? Any input would be greatly appreciated,cheers Trey
    • flyjoe180
      • Jan 2012
      • 13103
      • Joe
      • Earth
      #32
      Firstly great recovery on those decals Trey. I wouldn't have noticed the (very slight) decal misplacements if you hadn't said anything. I'd go for a light staining and streaking as you suggested, as RAF fighters were kept pretty clean. Maybe some light chipping in keeping with the reference photo, and some more around the wing panels etc where the aircraft has been serviced regularly. As for the underside, can't say, but I'd go for a few oil streaks and stains but keep it light as with the rest of it. Having cleaned my fair share of aeroplanes, I know what you mean about the undersides. A real ugly job at the best of times, but the RAF would have had guys on the job anyway I would think.
      • Vaughan
        • Apr 2011
        • 3229
        #33
        All's looking you would have never of guessed that you had had any problems( have just started on my decals which have silvered badly despite the clear coats) it's really coming to life now.
          Joe thanks,appreciate the input and I decided to go with with some very subtle weathering.
          Vaughan thanks as well and sorry to hear about your decal struggles,hope you get it sorted.
          Weathered to a point that I'm sastified with ,hope its not too much,what do you all think?
          • monica
            • Oct 2013
            • 15169
            #35
            most in-presage paint work on this one ,great job very well done
              That's going to look totally awesome when finished great work, you are to critical on yourself, I wouldn't known anything about the white bands or the decals if you hadn't mentioned them. It still looks awesome to me.
              • flyjoe180
                • Jan 2012
                • 13103
                • Joe
                • Earth
                #37
                Trey, weathered to perfection for the effect you are after. Great work.
                • The Migrant
                  • Apr 2011
                  • 1268
                  #38
                  Weathering looks spot-on to me Trey; it's subtle enough that you can only just see it. Beautiful looking build.
                  I had similar issues with some Techmod F-18 decals, almost had to use a stapler as a decal solvent.
                    Looks very fine to me! The chipping effect on the wing (under cockpit) is very realistic
                    Excellent work!
                      You've nailed that subtle weathering Trey, it's looking just right.
                      • BarryW
                        • Jul 2011
                        • 6142
                        #41
                        She really is looking superb. I fully appreciate your decal problem, my least favourite job. I have found sometimes when I get this problem that using Microscale decal film helps
                          Thanks for all the great comments and advice/tips greatly appreciated ! finished thread can be seen here
                          http://www.scale-models.co.uk/community/threads/north-american-raf-p-51iii-1-48-tamiya-completed.28119/
                          cheers Trey
