1/72 Airfix Fw 190.....From Catalonia
  • stona
    • Jul 2008
    • 9889
    I'm going to make a start on this, kindly sent by Polux all the way from Catalonia.
    I'll build it out of the box and in the scheme provided. Jagdgruppe 10 is an interesting enough subject and a unit formed with an impressive sounding name from an experimental unit in an act of desperation towards the end of the war.
    There's not a lot to the kit.
    But what's there is very nicely molded and detailed.
    Should be fun
    Watch out for the fit problems that I found Steve - I'd recommend closing the fuselage & adding the cockpit tub from below.
    • stona
      • Jul 2008
      • 9889
      Where did you have problems? I've dry fitted the cockpit and fuselage and it seems okay. Haven't checked the wings to fuselage yet.
        These were my problem areas Steve
        [ATTACH]87533.IPB[/ATTACH]
        [ATTACH]87534.IPB[/ATTACH]
        [ATTACH]87535.IPB[/ATTACH]
        [ATTACH]87536.IPB[/ATTACH]
        Bear in mind that it is probably as much my ham-fisted building as any deficiency in Airfix's manufacturing!
        I'm sure that you'll have no such problems!
        • yak face
          • Jun 2009
          • 14078
          • Tony
          On first impressions this looks like a lovely new tool from Airfix , great surface detail but then i saw Patricks post!! Hopefully Patricks was just a one off, production line Friday afternoon special ,its such a shame if Airfix have not followed through the kits early promise with good quality control.Still looking forward to seeing the build steve , cheers tony
          • stona
            • Jul 2008
            • 9889
            Whilst I appreciate the sentiment I'm not so confident myself !
            Thanks for the piccies though, I'll be giving those areas some special attention.
            • flyjoe180
              • Jan 2012
              • 12664
              • Joe
              • Earth
              I did a dry fit of my one and it has no obvious gaps. Think your one may have been a bad mould unfortunately Patrick.
                Ouch!! Sorry Steve, I miss this one ops:
                I'm glad to see you building it!
                I know a Catalan guy that will follow this thread with many interest, he has one too
                  Even all the way down South I will be following with great interest :-)
                  Theuns
                  • tr1ckey66
                    • Mar 2009
                    • 3592
                    From one builds straight into another, I like your style! And it was a great gesture on Polux's part for providing the starting point.
                    I'll be popping by to see the progress
                    P
                      • 22851
                      Looks a very nicely detailed kit
                        Good start Steve, and excellent gesture Polux.
                        Now I just need to find an aileron to send to Polux
                        Francesco
                        • Alan 45
                          • Nov 2012
                          • 9833
                          I've wondered if this kit was new tool or not and now I know thanks Steve
                          • stona
                            • Jul 2008
                            • 9889
                            I've stuck most of this together. Luckily it fitted quite well, just a couple of cowling pieces needed a swipe of the sanding stick.
                            It's OOB except for a harness made from foil (the stuff that scalpel blades come in is perfect)
                              Seems a very nice model Steve!
                              I'm glad to know all goes well and he fit ok
                              The harness looks spot on
