Revell Learjet 35A/C-21 USAF/USAFE
    Cheers Ian that is how I thought it should be. easy enough to correct as they are only fixed with CA.
      • 22954
      #32
      Looking very good Terry
        Cheers Ian
        • flyjoe180
          • Jan 2012
          • 12958
          • Joe
          • Earth
          #34
          Looks good Terry. As Ian says, there is minimal dihedral on the tail planes.
            Thanks Joe I have rectified them this evening and they look as they should now.
              Tonight I have started some work on the engines. As there is a difference in the military variant I am altering them accordingly. I am going to add thrust reversers made from styrene sheet but before I do that I need to lessen the depth of the engine mount. On the Learjet 35A there is more of a moulded look to the engine as can be seen below. The left hand engine has been altered ready for the reversers to be added with a little more sanding to be done. Where as the right hand engine is how it came out of the box. [ATTACH]89929.IPB[/ATTACH]
              [ATTACH]89930.IPB[/ATTACH]
              [ATTACH]89931.IPB[/ATTACH]
                Looking good there keep it up terry
                • flyjoe180
                  • Jan 2012
                  • 12958
                  • Joe
                  • Earth
                  #38
                  Doe sit have bucket reversers on the exhausts Terry? Most early Learjets had no reversers, some had a drag chute. Doesn't make for efficient operation at short airfields, or indeed at any airfield if you drop the chute.
                    Looking good Terry, never realised what a nice looking aircraft this was.
                      Thanks guys, Joe it does indeed have the buckets I didn't know some of the earlier ones used break chutes. That would explain why on some pictures I have looked at they appear to have a cap on the tail of the airframe. All the ones that I have seen go through Fairford have had the buckets fitted. It has got me thinking maybe the USAF ones have been upgraded to give better operational capabilities.
                        Over the last couple of days I have modified the engines so as to fit the reverse thrust cans on. These are being made from styrene sheet with a masking tape stencil.[ATTACH]90129.IPB[/ATTACH]
                        [ATTACH]90130.IPB[/ATTACH]
                        [ATTACH]90131.IPB[/ATTACH]
                        [ATTACH]90132.IPB[/ATTACH]
                        [ATTACH]90133.IPB[/ATTACH]
                        [ATTACH]90134.IPB[/ATTACH]
                          a quick update on the engine progress.
                          The reverse thrust bucket doors are on and still need a bit of shaping once the hinge covers are added. There will also be a need for a small amount of filler.[ATTACH]90295.IPB[/ATTACH]
                          [ATTACH]90296.IPB[/ATTACH]
                          • flyjoe180
                            • Jan 2012
                            • 12958
                            • Joe
                            • Earth
                            #43
                            Nice job Terry.
