1/72 Bf 109 airfix dogfight doubles
    Hello
    Recently, I went for christmas shopping and saw this little airfix combo which includes a spitfire and a Bf 109 for 17 pounds. Firstly, I am going to build the Bf 109 and then the spitfire.
    [ATTACH]94475.IPB[/ATTACH]
    [ATTACH]94476.IPB[/ATTACH]
    The sprue has absolutely no flash and the parts seem to be of a very high standard. The panel lines are all inscribed rather than raised.
    [ATTACH]94489.IPB[/ATTACH]
    The cockpit only consists of 4 parts but that is ok because you won't really see it since this is 1/72
    The prop did seem to be quite fragile and I did end up cracking the frontal yellow prop cone so be careful when sanding and removing it from the sprue
    [ATTACH]94490.IPB[/ATTACH]
    The fuselage fits together very nicely without an major gaps
    [ATTACH]94491.IPB[/ATTACH]
    To me it seems that pre shading panel lines makes the model look a lot better
    [ATTACH]94492.IPB[/ATTACH]
    Pre shading works best with lighter colours such as this sky grey/blue
    [ATTACH]94498.IPB[/ATTACH]
    It is very hard to mask off everything perfectly on such small models.
    [ATTACH]94502.IPB[/ATTACH]
    I decided to airbrush everything for a nice flat finish
    [ATTACH]94503.IPB[/ATTACH]
    My model is starting to suffer from rough paint syndrome
    [ATTACH]94504.IPB[/ATTACH]
    The landing gears are so hard to attach since they are so small and are a very tight fit
    [ATTACH]94505.IPB[/ATTACH]
    I attached the canopy using some pva glue so it does not fog up the clear parts
    [ATTACH]94506.IPB[/ATTACH]
    the decals are really nice and are thin enough to fall into the panel lines with a bit of help from micro sol
    [ATTACH]94507.IPB[/ATTACH]
    Finally finished! Unfortunately, once I applied alclad aqua gloss the paint on the model started looking very rough and had small bumps in it. Otherwise, everything went perfectly.
    Hope you enjoyed the build, some more finished photos of it will be posted in the finished aircraft section of this forum tomorrow.
    Thanks for reading
  • flyjoe180
    • Jan 2012
    • 12946
    • Joe
    • Earth
    Great work Ivan, that look superb. Will watch for it in the completed section.
      That looks good, nice work so far.
      scott
        Nice work Ivan, looking forward to seeing more
        • Alan 45
          • Nov 2012
          • 9833
          Nice work Ivan and that's werner molders messy if I'm not mistaken
          • monica
            • Oct 2013
            • 15169
            Great work Ivan,do like it,very well done,
