Italeri Hudson Mk IV 1/72 scale.
  • rtfoe
    • 9230
    • Richard
    • Shah Alam, Malaysia
    #16
    Originally posted by Richard48
    Welcome back Wabble.Great to see you creating again Richard.Nice to see a Hudson.
    Rich
    Good to be back Rich...not many Hudsons being built so it is nice for a change.
    Wabble
    • rtfoe
      • 9230
      • Richard
      #17
      Originally posted by Jim R
      Nice to see this back on the bench. Moulded door looks to have been neatly removed. Ejector mark were a nuisance but well fixed.
      Hi Jim and Nick, yep, it was long overdue and had to be built. Opening the door was fun to make. Haven't used the drill for a while.
      Wabble
      • Mickc1440
        • 4859
        #18
        Nice to see you back Richard
        • rtfoe
          • 9230
          • Richard
          #19
          High Mick, just couldn't leave the build hanging here.
          Wabble
          • rtfoe
            • 9230
            • Richard
            #20
            Hi, continuation of the build. I made a boo boo by drilling out the Astrodome hole then finding out the version I was doing doesn't have one. A little strip and putty will fix that...
            Then I painted detail to the cockpit seats...
ID:	1270977 Click image for larger version
            And weathered the seatbelts.
            Next I glued the fuselage halves...
ID:	1270975 Click image for larger version
            And sanded down the joints.
            More later...
            Wabble
            • Airborne01
              • Mar 2021
              • 4368
              • Steve
              • Essex
              #21
              Good to see you back in harness Wabble!
              • rtfoe
                • 9230
                • Richard
                #22
                Hi Steve, couldn't leave you guys alone...
                Wabble
                • rtfoe
                  • 9230
                  • Richard
                  #23
                  Hi Guys, more work on the Hudson...
ID:	1272955 Click image for larger version
                  Painted up the IP and stuck it in...
                  Sanded down the turret fairing assembly...some dinks and gaps need puttying.
                  Got the wing halves cemented and used tape to hold them together at the leading edge to align and not have a step...saves sanding and cleaning up.
                  Wabble
