Andrew's 'Secret Santa' 1/72 Airfix Tempest V (post war)
    • 16311
    Looks a nice kit. Hope it goes together well. You have certainly come up with a lot to consider with that research.
    • adt70hk
      • Sep 2019
      • 10554
      #17
      Thanks Jim. There is indeed a lot to consider.....and not all of it definite....e.g. the yellow leading edges.
      Will have to give it some thought.
      ATB
      • Airborne01
        • Mar 2021
        • 4370
        • Steve
        • Essex
        #18
        Excellent research mate, looking forward to an excellent build!
        Sreve
        • Geoffers
          • Jan 2017
          • 2178
          • Geoff
          Excellent bit of “rabbit hole” exploring Andrew and makes sense.
          I think the yellow ring added to the roundels and wing leading edge was a wartime addition for quicker identification in the heat of battle.
          So as a post war aircraft it’s likely that it has had its paint stripped which increased its speed and had post war markings added, maybe
          Looking forward to watching your build.
          Geoff.
          • adt70hk
            • Sep 2019
            • 10554
            #20
            Forgot to upload a picture of the destructions commentary on the drop tanks....
            • adt70hk
              • Sep 2019
              • 10554
              #21
              Sreve
              Geoff.
              Thanks for the support chaps.
              Geoff
              in terms of the yellow/IFF issue, I am sure you're right.
              In terms of the silver/BMF, looking back at Chris Thomas' comments, he actually posted an extract from a book he wrote for Eduard, which can be loosely summarised as follows:
              • they did do trials with a BMF Tempest in the war but the results were seemingly inconclusive
              • their had been discussions in the RAF/Air Ministry in 1945 about the need for camo at all, given that many the USAAF aircraft were doing without it.
              • the removal/replacement of the camo came into effect in Feb 1946 stating that "...the agreed schemes and the new Day Fighter Scheme was to be an all-over ‘silver’ painted scheme, with as smooth a finish as possible."
              • however some units, simply stripped the current camo off their planes but then discovered that keeping bare metal finish in good condition was tricky, so they started to paint them silver
              • in the case of this plane, the pilot had the paint stripped off in April 1946, albeit it was soon replaced by a Tempest II
              Therefore this plane is a bare metal finish with the different shades seemingly being down to the 'grain' of the aluminium when laid in alternating directions. As I said, I will have some fun trying to replicate the effect.
              HTH.
              ATB
              • Geoffers
                • Jan 2017
                • 2178
                • Geoff
                Hello Andrew.
                Have you considered doing it with real metal foil?
                Jen at Jenesis models does a series of tutorials on her YouTube channel.
                It might be more effective than paint, it’s one of the things I’ve been meaning to try for a while but haven’t got around to it yet.
                Geoff.
                • adt70hk
                  adt70hk commented
                  Editing a comment
                  Hi Geoff, not this time but might think about it in the future. Thanks for the link.
              • adt70hk
                • Sep 2019
                • 10554
                #23
                OK chaps
                So by my standards I have made positively lightening progress but before the progress shots, some BIG news........
                .................Airfix have finally done an update RAF WWII era pilot.....at least for this kit. I'll let that sink in.......
                That's right.....the 1960s amorphous 1960s era blob has finally been retired. Not sure if it will apply to all kits but the pilot in this one is much better done and, more importantly, I didn't have to cut his feet off to get him in!
                Anyway update as follows and as you can see a lot has happened:
                • Cockpit done...didn't spend a huge amount of time on it as most of it won't be seen
                • Pilot done...likewise didn't spend too much time on him
                • Fuselage halves joined
                • Wings attached
                • Any filling needed completed and sanded
                • Now ready for priming.
                Thoughts on the kit:
                • Surprising amounts of flash on some pieces for such a new mould...nothing major but it's there all the same
                • Fit...generally very good...dry fit looks like it's almost been glued in some places, with no gaps, even on the wings/fuselage joins
                • Most fit issues almost certainly my fault...especially on the fuselage.
                • They helpfully label some parts port or starboard!
                • The drop tanks have mouldings for fuel lines you can paint if you're VERY careful...I just repeatedly dropped very thin paint into the groove
                • Instructions slightly unclear at one point and so the insert to complete the top of the cockpit is in hindsight not pushed down at the front but not badly so
                • Only real complaint is the wing fit/design. As many reviews note the trailing edge is far too thick. However, my main complaint is the way they go together. In this scale you often see the the trailing edge being moulded as a single piece that is part of the top wing half, with a nice smooth edge. The bottom half then butts up against this away from the trailing edge. In this case though the two halves are perfectly matched, with the join on the trailing edge, making a clean join much harder to achieve, at least IMHO
                ACW as usual.
                ATB
                PS sorry for so many pics....but I have got a lot done
                Flash.....a number of pieces on this sprue were affected...plus the port starboard labelling
                Some dry fit shots....you get the idea
                The internals and new pilot.....
                Drop tank fuel line
                Ready for priming....
                • scottie3158
                  • 14638
                  • Holbeach
                  #24
                  Andrew,
                  Looking good mate. It does seem strange to have so much flash on a new mould. The pilot is a great improvement but I can't help thinking that he would look better if they gave him a bit of character by turning his head slightly to one side rather than that straight ahead stare you always get.
                  • flyjoe180
                    • Jan 2012
                    • 13103
                    • Joe
                    • Earth
                    #25
                    Your Tempest went together well Andrew, look forward to the paint job
                    • HAWKERHUNTER
                      • Feb 2012
                      • 2074
                      • Steve
                      • Halifax, West Yorks.
                      #26
                      Nice progress Andy.
                      • adt70hk
                        • Sep 2019
                        • 10554
                        #27
                        Andrew,
                        Originally posted by HAWKERHUNTER
                        Nice progress Andy.
                        Thanks as always for the support chaps. It is really appreciated.
                        Scottie - You make a very good point about the pilot. I have a couple of AM 1/72 ones and they do that. It does make them look a bit more interesting.
                        Thanks again.
                        • adt70hk
                          • Sep 2019
                          • 10554
                          #28
                          Ok chaps....
                          So primer is on which shows some very minor filling is needed but is so minor I may let it got. Not as quite as smooth as the Mustang primer job but not too shabby.
                          Also, in my last post, I forgot to say I have also finished the wheels and prop/spinner. The spinner is red as that is what was actually on the plane, not silver as Airfix have depicted.
                          ACW as usual.
                          ATB
                          • adt70hk
                            • Sep 2019
                            • 10554
                            #29
                            Ok chaps....so mottling is now done.....such an easy technique with a myriad of possible effects!
                            Next up is the green on the wheel wells and undercarriage.
                            ACW as usual
                            ATB
                            • adt70hk
                              • Sep 2019
                              • 10554
                              #30
                              Okay so a short update.....
                              ....interiors of the wheel wells and the like have now been painted interior green-grey, as this is apparently the way it was done.
                              Helpfully the bits of plastic for the 'in flight' option of U/C and wheel well covers are single pieces and so double as a good template for DIY masks.
                              They also helpfully double as blanks to keep the new green wheel wells covered for when the main coat goes on, although the tolerances are so tight with the interior paint in place that I had to scrape a bit of the plastic off around the edge of them to get them in place.
                              And after I took these shots, the first coat of aluminium went on, so another update will follow tomorrow.
                              ACW as usual.
                              ATB
