Airfix 1/72 Spitfire Vc
  • yak face
    • Jun 2009
    • 14237
    • Tony
    #16
    The nose section has now been glued and the tailplanes and rudder have been fitted. The two outer cannons for some reason are separate and these have been added too . The whole airframe has had a check over and everything looks ok. The gunsight was painted and fitted then after masking , the screen and rear section of the canopy were glued on with non fogging CA. The morse code signal light on the top of the fuselage is moulded solid on the kit whereas it is a clear lamp . I got some clear sprue and sanded it to an oval shape then heated and stretched it .After cutting it I held it close to the candle flame till it started to melt slightly and this gave me an oval clear shape . The solid kit lamp was sanded off and a hole drilled so the new on will fit snug.
ID:	1259407 Click image for larger version
ID:	1259409 Click image for larger version
ID:	1259411 Click image for larger version
ID:	1259410 Click image for larger version
    • Miko
      • Feb 2024
      • 729
      #17
      Coming along nicely, can't have enough spitfires in the stash!
      • HAWKERHUNTER
        • Feb 2012
        • 2044
        • Steve
        • Halifax, West Yorks.
        #18
        Just had a catch up Tony. Some good work gone into this one. Coming along nicely.
          • 16191
          Missed the start of this Tony, sorry. These new Airfix kits are certainly very good and represent great value for money. Off to an excellent start, lots of careful neat work. I've often considered that non fogging CA - does it work OK?
          • yak face
            yak face commented
            Editing a comment
            Thanks jim , no need to apologize its all too easy to miss stuff . The non foghing CA is brilliant stuff , bit expensive at about £9 a bottle but it does what it says . I use it for canopies most times now
        • Richard48
          • 2176
          • Richard
          • Clacton on Sea
          #20
          Looks great Tony.To my shame i have never built a spitfire or indeed a Hurricane in my life.Ive got the Airfix mark 1a and i should build one at least.
          • yak face
            yak face commented
            Editing a comment
            Thanks richard , if its the newer tool Airfix mk1a then it builds up beautifully , you’ll love it , cheers tony
        • yak face
          • Jun 2009
          • 14237
          • Tony
          #21
          After a tricky mask up of the open cockpit its had a coat of grey primer . Nothing serious needed sorting just a few swipes of acrylic putty here and there . Its now had the underside azure blue . Click image for larger version
ID:	1259486 Click image for larger version
ID:	1259488 Click image for larger version
          • flyjoe180
            • Jan 2012
            • 12946
            • Joe
            • Earth
            #22
            Looking very good Tony
            • yak face
              • Jun 2009
              • 14237
              • Tony
              #23
              First upper colour on Click image for larger version
              • colin m
                • 9024
                • Colin
                • Stafford, UK
                #24
                'Achtung Spitfire' Guess what film I watched (again) last week ? But yes, it's always good to see a spitfire being built. And I do love a desert scheme.
                • PaulTRose
                  • Jun 2013
                  • 7108
                  • Tattooine
                  #25
                  Spring chicken to shitehawk in one easy lesson?
                  Takkatakkatakkatakka
                  Per Ardua
                    • 22954
                    #26
                    Just seen and caught up on this one Tony, cracking work so far.
                    • colin m
                      • 9024
                      • Colin
                      • Stafford, UK
                      #27
                      Of course, what else.
                      • yak face
                        • Jun 2009
                        • 14237
                        • Tony
                        #28
                        I wanted to try and get a sun bleached look to the upper side paintwork so I added a few drops of white to the mid stone and gave the top of the fuselage , wings and tailplanes a random blotching . Once ive applied the dark earth I’ll do the same to that which will hopefully look like its faded in the desert sun. Click image for larger version
                        • yak face
                          • Jun 2009
                          • 14237
                          • Tony
                          #29
                          After a masking session I got the dark earth on and followed that with a lightened mix over the top surfaces to hopefully try and give the impression of sun bleaching. After overnight curing it was unmasked and its now had a coat of gloss ready for the decals . Click image for larger version
ID:	1259979 Click image for larger version
ID:	1259981 Click image for larger version
ID:	1259980 Click image for larger version
ID:	1259978 Click image for larger version
                          • HAWKERHUNTER
                            • Feb 2012
                            • 2044
                            • Steve
                            #30
                            Thats come out well Tony.
