Phils' 1/48 Eduard Fw190 D9
  • PhilJ
    • May 2015
    • 1145
    #46
    Originally posted by \
    Love the work you have put into this build Phil. Very interested in your thoughts on the paints as I am looking at clearing my old stock and starting anew. I do love Tamiya paints but they just don't make it easy with the colours, the Mr Hobby have the colours and appear much like Tamiya so could well be the route to go down.
    Definitely give them a go Graham, the mr hobby aqueous is water based and I have been thinning it with mr hobby levelling thinner (which I decantered in to a dropper bottle, it also work well with famous and the main bottle will last forever). I have but haven't tried their lacquer based "mr Color" yet but that's supposed to be good when also thinned with the same thinner.
    Done some more airbrushing tonight, some block and some intricate camo work. It went down a treat again and even though this was my first time doing freehand camo work and it took me a while, it stayed fluid and sprayed no probs.
    Phil
    • PhilJ
      • May 2015
      • 1145
      #47
      So four colours are involved with the rest of the scheme. The greens and brown violet on the tail are all mr hobby aqueous, using these paints again I must say I'm really impressed, the levelling thinner apparently has a retarder and it sprays so well, considering this was my first time doing freehand camo work some of the colours where in the cup for a while while I faffed about but I had no drying or blockages once!
      I want to add some paint chips by dry brushing, shall I varnish first or do the chips then varnish and add decals?
      Sorry for the ropey pictures any comments criticisms on the camo would be appreciated
        That looks really good Phil, the colours are deep & rich with a great finish.
        I'd varnish, decal & then matt coat before adding the chips. It'll take better over a matt surface than a gloss one & any chips caused through wear & tear would happen after the markings were painted at the factory.
          Wow, Phil.......great work.....looking forward for the "Rollout"!!
            • 22983
            #50
            That is looking very good Phil
              Is this finished yet?
              • PhilJ
                • May 2015
                • 1145
                #52
                Nope been so busy mate, I have done more though. The canopy is done all I need to do is get the step up, pilot tube and little bits on them I'm done. Hopefully should have some completed posts this weekend
