Very nice work with the decals Vaughan
Revell 1/72 Avro Shackleton AWE2
That is looking quite impressive. For all the issues, you are making a Stirling job of this Vaughan.Comment
Whenever I do masking (eg. camo) I find some bleed under the tape. I use Tamiya yellow tape, press the edge down firmly and coat that edge, both the part and the tape, with a thin line of Pledge (to seal it). I never get a crisp sharp edge.Originally posted by \I think next time I haven't got broken/dash walkway lines I'm gonna try masking and painting them.
Has anyone conquered this?Comment
Hi Steve, not sure what the pledge is for? I have never had any bleed when using Tamiya tape so not sure what's happening here, maybe it's a smoothness thing Steve? Are you getting the surface nice and smooth before painting and masking? Maybe PM me in case we get our collar felt for hijacking this threadOriginally posted by \Whenever I do masking (eg. camo) I find some bleed under the tape. I use Tamiya yellow tape, press the edge down firmly and coat that edge, both the part and the tape, with a thin line of Pledge (to seal it). I never get a crisp sharp edge.
Well it's taken me an hour to put down this last set of walkways. A nightmare! It's not perfect but it's as good as it's going to get. Thank god that's over with. Now I can get on with spraying the fuselage which should be a darn sight easier.
Attached FilesComment
Have to say Vaughan, this is looking tidy. From the pics you would have no idea of the fight you have had with it.Comment
Some more progress since last Tuesday main undercart attached. Fuselage is now painted plus two coats of Klear and decaling has started in ernest it's going to take some time this is my second day. Have found leaving the wings detachable has made decaling somewhat easier. Props are in the process of being painted but as Colin said it's a matter of masking spraying masking spraying it just goes on!
Guest -
Thanks guys. Decals still in progress it's going to take a while. So in the mean time I've finished off the props. Who invented contra rotating props? and at 72nd scale
. Well they're finished and with a coat of Klear. Guess whats next? that's right more decals! I think I will start on those tomorrow and give my eyes a rest
Very nice. I painted the white tips on mine today.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
