HK Models 1/32 scale D. H. Mosquito
  • BarryW
    • Jul 2011
    • 6142
    #121
    Hi Vaughan,
    Well if it is it has been very carefully molded!!!
    It is actually some of the exceptionally fine surface detail on the kit.  There was actually a very fine mold seam running down the centre of it and removing the seam had to be done with considerable care to ensure that I also did not remove this detail.  I believe it is representing something that they ran down a join where two plywood sheets butted against each other.  This detail appears in other places.
    here is a close up photo that shows the detail:
    The surface engraving on this kit is unrivalled, simply exquisite, as good or even better than Tamiya have achieved.
    Anyway - I did not manage to finish the masking last night and will need to finish it tonight but I did manage to get the trickier masking done with various widths of Tammy tape including some of their curved tape.  I also used some shaped Maskatar masking for the curved section at the rear to get clean curves it does not show on the photo below because it is a transparent grey and all you can really see is the Tammy tape around it.
    • Vaughan
      • Apr 2011
      • 3229
      #122
      Ah...... that throws a different light on it. I can see that it's ment to be there in your close up photo. Looking forward to the final stages.
      • BarryW
        • Jul 2011
        • 6142
        #123
        Here she is, all dressed up for a base coat of RAF Ocean Grey.
        i am using AKI Air Series for the main base coats supplemented by Vallejo Model Air.  I find they spray beautifully, even better than Vallejo MA.
        I spray in a series of light coats at about 20psi neat unthinned with a .4 needle.
        Here she is after the first pass with the airbrush
        then after the second pass
        then the third pass
        but it's still not finished. I have decided not preshade as you can see and just rely on post shading.  So I mixed the base colour with 25% white and thinned it about 25%. I then sprayed into the middle  of panels and along areas that would catch the sun. I spayed at about 10 psi
        This is how it then looked
        As you can see the colour is now well modulated but it needs one more touch to get the effect I want.  After cleaning the airbrush I mix the base colour about 25% to 75% thinner and then do a mist coat at about 30 psi to knock back the contrast and get the more subtle modulated effect I want.
        As you can see below the mist coat helps blend the base colour while improving the overall effect
        the process is very controllable and foolproof
        Tomorrow after leaving it 24 hours to cure I will give it a very light sanding and wipe it down with a damp cloth before masking up for RAF Dark Green   I will mask it with this below
        this is the part of the build I really enjoy
        • BarryW
          • Jul 2011
          • 6142
          #124
          Looking at the pics on the big screen in the office the Ocean Grey look washed out and far too light - it really is Ocean Grey and is a darker in real life.
          • dave
            • Nov 2012
            • 1844
            • Brussels
            #125
            Looking Good.  I will have to try your approach to the black.
              Coming along nicely there Barry mate. Interested to see the clever putty being used to do the camo.
              • BarryW
                • Jul 2011
                • 6142
                #127
                RAF Green done..
                the masking material is excellent it sinks into the detail and stops any bleed. Very easy to manipulate as well
                here is the aircraft just before the mist coat.
                the masking material does not stick
                 and just lifts away.
                I spent just seconds removing the mask after painting
                there is no bleed and it looks spot on, any imperfections you see in the photo is on the mask protecting the black sides
                I will give the paint 24 hours to cure before removing most of the remaining masking material
                  • 22983
                  #128
                  Just caught up Barry some awesome work mate
                  • BBdave
                    • Aug 2014
                    • 825
                    #129
                    Great job I keep meaning to pick some of this putty up to try.
                    • BarryW
                      • Jul 2011
                      • 6142
                      #130
                      First some pics with the masking removed except for the u/c and transparencies
                      i have just finished two gloss costs with Alvlad Aqua Gloss to prepare for decalling
                      i I will leave it to cure and start decalling tomorrow.
                      Below are my best friends for decals. A cup warmer and decal solutions.  Keeping the water warm helps speed up the process for which the cup warmer was a real breakthrough
                      • flyjoe180
                        • Jan 2012
                        • 13100
                        • Joe
                        • Earth
                        #131
                        Looks great Barry, coming along very nicely indeed. Cup warmer = fantastic idea.
                        • Vaughan
                          • Apr 2011
                          • 3229
                          #132
                          Barry where do you get the Clever Putty from, how much does it cost and can you re-use it?
                          • BarryW
                            • Jul 2011
                            • 6142
                            #133
                            Hi Vaughan.  I just Googled for it and I cannot remember where I got it from.  I got two tins in all and yes it is reusable.  This is the second time I have used it.
                              • 18302
                              Seen it in e-bay. Price from 4,95 right up to 7,50 per tin! Plus post!  It is also sold as a recovery aid so I am sure it can be found cheaper...
                              I remember when we had silly putty. I guess it got the smarts...
                                • 18302
                                Looking very nice Barry.
                                You are going to need a bigger turn table when you start the Lancaster.....
