Special Hobby 1/32 Tempest V
  • yak face
    • Jun 2009
    • 14309
    • Tony
    #16
    Top work steve , beautifully painted . The harness looks superb , are the hgw belts a fiddle ? Ive never used them. Cheers tony
      • 18302
      Ditto that.  /\
      • BarryW
        • Jul 2011
        • 6142
        #18
        That cockpit is exceptional...
        • stona
          • Jul 2008
          • 9889
          #19
          And it's all out of the box !!!! I think that Special Hobby have raised their game significantly with this kit. The cockpit is quite a complicated structure. but it all went together quite easily, though not quite as per the instructions.
          The HGW harness is very nice too. It was a fiddle Tony, but then so are all the others that require assembly. I generally use the RB Production harnesses, but I was very impressed with the way this one took a very dilute oil wash to pick out the detail and grubby it up a bit. To the naked eye it looks a lot like webbing.
          • stona
            • Jul 2008
            • 9889
            #20
            It's hardly modelling weather here in Birmingham today, but I've just got in and thought I'd test fit the wings of the Tempest, which I built yesterday, to the fuselage.
            The fit of these non main stream kits can be problematic and is understandably a concern to many.
            Here you see the fuselage dry fitted to the wings, I haven't applied any glues yet. As you can see the fit is excellent, in fact it's about the best I've seen in any kit which I've built in the last fifteen years or so. 'Chapeau' to Special Hobby for this one.
            • tr1ckey66
              • Mar 2009
              • 3592
              #21
              This is looking very good!
              Steve, you'll have me reaching for my credit card and buying the kit if you're not careful!
              P
              • stona
                • Jul 2008
                • 9889
                #22
                P
                Well Paul, far be it from me to incite anybody to spend their hard earned cash, but if you want a 1/32 scale Tempest this is definitely the one to get
                You can see from the way the entire area in front of the fire wall is a separate assembly, and from the 'unused' parts on the sprues, that there will be other Marks of Tempest coming along in the future too.
                • tr1ckey66
                  • Mar 2009
                  • 3592
                  #23
                  It's certainly a temptation but I'll build the PCM kit first and see how that turns out.
                  Maybe in the future
                  Paul
                    The instructions do look to be a bit of a mess, but the finished cockpit looks exceptional.
                    Good job mate
                    • stona
                      • Jul 2008
                      • 9889
                      #25
                      Slow progress as I'm not getting much time at the moment.
                      The main construction is finished and I've primed the model. There are a couple of 'ghost' seams which have appeared, but once fixed I can start painting.
                      • BarryW
                        • Jul 2011
                        • 6142
                        #26
                        Beautiful work Steve
                        • stona
                          • Jul 2008
                          • 9889
                          #27
                          Underside is sprayed Medium Sea Grey and masked and the Ocean Grey is on the upper surfaces. As you can see I've laid my Blu-Tac worms along the upper camouflage demarcations.
                          I don't try to rigorously follow every curve and squiggle of the original pattern, but I do make sure that the demarcation runs through a selection of 'cardinal' points in order to get the overall shape and size correct.
                          All I have to do now is mask the Ocean Grey areas and spray the Dark Green
                          • tr1ckey66
                            • Mar 2009
                            • 3592
                            #28
                            Looking very good Steve.
                            That's some nice 'tight' masking (well, outlining!) should spray up to a great camouflage.
                            P
                            • stona
                              • Jul 2008
                              • 9889
                              #29
                              Always looks a bit of a mess with the Dark Green and masking on
                              I'm hoping to post shade this later today and unmask it before I set off for a couple of days away in the morning!
                              • stona
                                • Jul 2008
                                • 9889
                                #30
                                Voila!
                                I have paint masks from Maketar for the markings etc so more spraying in about a week's time
