My Little Harry Tate completed build blog
  • rtfoe
    • 9204
    • Richard
    • Shah Alam, Malaysia
    #31
    Hi, I've been away down south in Singapore last weekend and have not done any bench time or been on the net.
    Wouter and Steve, thanks for the comments. The builds seem a lot but this is one that was completed about 3 years back but being shared here. The springs ...so that is what they are, well in that scale I thought painting them with washes and highlights would be enough.
    • rtfoe
      • 9204
      • Richard
      #32
      Continuation of the old build...I cut disc from styrene rod for fuel caps and lengths for a sight.
      [ATTACH]304587[/ATTACH]
      Then added bracings on the top wing...this would hold some of the rigging.
      [ATTACH]304588[/ATTACH]
      With my trusty drill bit and motor tool I pre drilled the wings that would take the rigging later on...
      [ATTACH]304589[/ATTACH][ATTACH]304590[/ATTACH][ATTACH]304591[/ATTACH]
      I then replaced the engine top air scoop with one made from copper sheet.
      [ATTACH]304592[/ATTACH]
      The profile of the new airscoop looked crisper than the kit part. A hole was predrilled to take on the rod leading from the Vickers gun to the propeller to synchronise the firing of the gun.
      [ATTACH]304593[/ATTACH]
      Thats all for now.
      • rtfoe
        • 9204
        • Richard
        #33
        Continuation with the rigging drilling along the fuslage and tail...
        [ATTACH]305067[/ATTACH]
        The syncro rod and Vickers cradle attached...
        [ATTACH]305068[/ATTACH]
        First coat of primer sprayed...
        [ATTACH]305069[/ATTACH]
        Added the cocking lever to the Vickers and proceeded with detail painting of the ejector chute in brass...and the lever handle in brown
        [ATTACH]305070[/ATTACH]
        Highlighted the raised details with steel...
        [ATTACH]305071[/ATTACH]
        Sprayed the underside with off white concentrating more paint on the raised ribbing.
        [ATTACH]305072[/ATTACH][ATTACH]305073[/ATTACH]
        More next...
        • scottie3158
          • 14437
          • Holbeach
          #34
          Richard,
          Great work on the added detail really looking the part.
          • rtfoe
            • 9204
            • Richard
            #35
            Thanks Paul,
            It get hairrier when the rigging starts.
              And this is in 1/72 !
              Richard, just had an enjoyable time reading through this, what a superb piece of work. That Lewis Gun is a joy to see .
              I've never seen this before, must have been before I joined the merry throng
              • flyjoe180
                • Jan 2012
                • 12664
                • Joe
                • Earth
                #37
                Super work Richard, a great build thread
                • Mickc1440
                  • 4826
                  #38
                  I remember the finished article but not all of the amazing detail work that went into it, mind blowing miniature work Richard.
                  Mick
                  • rtfoe
                    • 9204
                    • Richard
                    #39
                    Thanks John, Joe and Mike. Glad you like it. It doesn't just stop at the plane build...there will be more on the figures and groundwork.
                    • rtfoe
                      • 9204
                      • Richard
                      #40
                      Hi, in some plan drawings provided by a fellow modeler from MM days I noticed a square opening at the bottom of the fuselage. On investigating it was an apature for an attached camera for recce.
                      [ATTACH]305403[/ATTACH]
                      I cut out the opening and fashioned a lip surrounding it with thin card.
                      [ATTACH]305404[/ATTACH][ATTACH]305405[/ATTACH]
                      You will have noticed the masking of the wing underside reccessed about 1mm. The surface colour overlapped the edges and a thin strip of the underside.
                      [ATTACH]305406[/ATTACH][ATTACH]305407[/ATTACH]
                      The camera was scratched and support added to the back so it could be glued on the inside of the top panel in the fuselage.
                      [ATTACH]305408[/ATTACH]
                      More to come.
                        Ooooh Nice. :smiling3:
                        • Fernando N
                          • 2448
                          #42
                          Very nice scratch-building work Richard, especially like the guns.:hungry:
                          Fernando
                          • Steve Jones
                            • 6615
                            #43
                            A wonderful update and its all going in the right direction
                            JR - stop looking at yourself in the mirror:smiling3:
                            • rtfoe
                              • 9204
                              • Richard
                              #44
                              Guys Muchos Gracias...
                              John R... same exclamation I get when looking in the mirror. Thanks bro.
                              Fernando... the guns were fun to build... a bit crude best viewed from a safe distance.
                              Steve... thanks, glad that it has turned out ok. So far it has gone to Shizuoka and back safe.
                                • 16029
                                Hi Richard
                                Really enjoying being reminded of just what a superb piece of modelling this was.
