Hi,
The camera construction was very enjoyable. at first I had to refer to references from the internet about cameras during that era. Interestingly professional photographers nowadays still use the bellows for large print photography except the plates have been replaced with digital cartridges.
[ATTACH]311283[/ATTACH][ATTACH]311284[/ATTACH]These were good enough to work from.
[ATTACH]311266[/ATTACH]
Above was my rough sketch for a scale plan and below were the prepared components for assembly...
[ATTACH]311267[/ATTACH][ATTACH]311269[/ATTACH]
Putty helped with the sculpting for the bellows.
[ATTACH]311270[/ATTACH][ATTACH]311271[/ATTACH]
Always checking against the figure for scale.
[ATTACH]311272[/ATTACH]
The shroud was made with flattened two part putty and attached with the help of a tooth pick and teased into shape.
[ATTACH]311273[/ATTACH]
I attached the assembly with blu tac hanging at an angle to let gravity do the rest as the putty cured. The angle was to create flow blown by the breeze.
[ATTACH]311274[/ATTACH][ATTACH]311275[/ATTACH]
Primed with black and the wood parts with yellow.
[ATTACH]311277[/ATTACH][ATTACH]311278[/ATTACH]
Brass and silver for the metallic parts were brushed on.
[ATTACH]311279[/ATTACH]
And finally a coat of varnish to seal it all in.
[ATTACH]311280[/ATTACH][ATTACH]311281[/ATTACH][ATTACH]311282[/ATTACH]
