Modelcraft 1/48 F82B ‘Twin Mustang’
  • Dave W
    • Jan 2011
    • 4713
    #46
    I’ve glued the two fuselages to the centre section and also glue the horizontal stabiliser in place. I had previously glued the upper half of the centre wing in place. Managed to remove it and only caused damage to the trailing edge of the lower section. Not a problem. Just a bit more filling,sanding and rescribing to do!.
    [ATTACH]322411[/ATTACH][ATTACH]322412[/ATTACH][ATTACH]322413[/ATTACH][ATTACH]322414[/ATTACH][ATTACH]322415[/ATTACH][ATTACH]322416[/ATTACH]
      I think I’d move the Phantom out of the way for fear of knocking it over or dropping something on it when working on the Twin Mustang
      • Dave W
        • Jan 2011
        • 4713
        #48
        Originally posted by Jakko
        I think I’d move the Phantom out of the way for fear of knocking it over or dropping something on it when working on the Twin Mustang :smiling3:
        As my Daughter would say “lol!”
          Dave .
          I thought gaps were part of modelling ! I have them even on good kits :smiling2::smiling2:
          You seem to be doing OK.
          John.
          • Dave W
            • Jan 2011
            • 4713
            #50
            Dave .
            John.
            This was normal modelling for me years ago. I've been spoilt by new kits like the Zoukie Mura Phantom in the photo. Everything fitted perfect on that one and only a tiny amount of filler needed on a join under the radome.
            • Dave W
              • Jan 2011
              • 4713
              #51
              I’ve glued a piece of plastic card to one end of the centre wing upper half and sanded it to shape. Now glued in place.
              [ATTACH]322978[/ATTACH][ATTACH]322979[/ATTACH][ATTACH]322980[/ATTACH]
              • Dave W
                • Jan 2011
                • 4713
                #52
                The instructions say to ‘drill holes in lower wings at marked positions for tanks’. There are no marked positions. So I am having to best guess them from photos. Meanwhile the filler fest continues .
                [ATTACH]323108[/ATTACH]
                  I thought, “Why is he posting a picture of a chair?” and only then realised it’s part of the picture of the model That looks like it had quite some gaps, yes. As for the holes: if you can find a front view with the tanks in place that also shows the wingtips, you can measure in that and do some calculations based on the size of the real thing.
                  /me does a little searching
                  Ah, here we go:
                  [ATTACH]323111[/ATTACH]
                  Wingspan of the real aircraft is 15.62 metres. Using the ruler tool in Photoshop, I find the wingspan in the photo to be 728 pixels, and the distance from the left wingtip to the pylons under that same wing to be 94 and 158 pixels. That translates to 202 cm and 339 cm, or in 1/48, 42 mm and 71 mm in from the tip of the wing.
                  • Dave W
                    • Jan 2011
                    • 4713
                    #54
                    Thanks Jakko.Ive based my measurements on the position of the star n bars under the wing for the outboard pylon.Then I measured halfway between the outboard pylon and the wing root for the inboard pylon position.As you've gone to all that trouble I will mark out one wing with your measurements and see what it looks like.
                    • colin m
                      • 8929
                      • Colin
                      • Stafford, UK
                      #55
                      I looked twice as well !
                      • Dave W
                        • Jan 2011
                        • 4713
                        #56
                        I initially thought id posted a pic of the chair in my digs as well!. When I tried to remove it I realised it was part of the same pic!.
                          Please let us know how much it differs. I won’t guarantee my measurements are any more accurate than what you have now, but it seemed better than having to eyeball it completely
                          • Dave W
                            • Jan 2011
                            • 4713
                            #58
                            Please let us know how much it differs. I won’t guarantee my measurements are any more accurate than what you have now, but it seemed better than having to eyeball it completely :smiling3:
                            As you can see from the photo Jakko, your measurements are slightly different to mine.But as you took the trouble to help me I am going to use your figures. All I need to do now is work out how far forwards (or backwards) to mount the pylons.
                            [ATTACH]323162[/ATTACH]
                              I suppose I’ll now have to find a photo of the underside and measure that
                              Maybe this photo from Warbirds News will come in handy, it shows the position pretty well I think:
                              The thing under the wing seems to be braced between the two pylons.
                              • Dave W
                                • Jan 2011
                                • 4713
                                #60
                                I
                                I suppose I’ll now have to find a photo of the underside and measure that :smiling3:
                                ve drilled holes for the pylon before I saw your photo. No problem though.I will drill some more and move the pylon forwards a few millimetres.
                                [ATTACH]323164[/ATTACH][ATTACH]323165[/ATTACH]
