Airfix 1\24 Hawker Typhoon (second bite)
  • peterairfix
    • Jul 2012
    • 11144
    As my last one got left for to and parts have gone walkabout so it's time to start a new one and as I know what I am in for it shouldn't be that scary.
    So here's the contents of the box.[ATTACH]324838[/ATTACH][ATTACH]324839[/ATTACH][ATTACH]324840[/ATTACH][ATTACH]324841[/ATTACH][ATTACH]324842[/ATTACH][ATTACH]324843[/ATTACH][ATTACH]324844[/ATTACH][ATTACH]324845[/ATTACH][ATTACH]324846[/ATTACH][ATTACH]324847[/ATTACH]
  • scottie3158
    • 14585
    • Holbeach
    Peter,
    That should keep you out of mischief for a while. I will pull up a chair and follow along.
      • 16197
      Hi Peter
      That is a lot of plastic. As Scottie says it will keep you busy for quite a while.
      • stillp
        • 8296
        • Pete
        • Rugby
        Interesting kit, I'll be watching.
        • peterairfix
          • Jul 2012
          • 11144
          After what seemed an age of cleaning mould seems I have finished off the first page of construction .
          And here's the result.[ATTACH]325164[/ATTACH][ATTACH]325165[/ATTACH]
          • Dave W
            • Jan 2011
            • 4713
            Looking good Peter. I’ve been building one of these on and off for the past year or so. It was all going well until I came to fit the engine cowlings. Gaps galore. Hopefully I will finish it soon.Look forward to seeing yours come together.
              • 18302
              Try not to lose this one
              • peterairfix
                • Jul 2012
                • 11144
                Here's some more work done this takes me to the bottom of page two.
                And I have had ago at the pilot.[ATTACH]325410[/ATTACH][ATTACH]325411[/ATTACH][ATTACH]325410[/ATTACH][ATTACH]325411[/ATTACH][ATTACH]325412[/ATTACH]
                  Wow! A lot to put together. Hope it all aligns accurate to not cause problems. Looking really good and pilot is together. Going to have to follow this :thumb2:
                  • peterairfix
                    • Jul 2012
                    • 11144
                    Despite being a bit busy i have managed to get some more parts painted.[ATTACH]325634[/ATTACH][ATTACH]325635[/ATTACH]
                    • scottie3158
                      • 14585
                      • Holbeach
                      Peter,
                      Coming on nicely.
                      • Dave W
                        • Jan 2011
                        • 4713
                        Everything lines up really well if you take your time with it. The only bad fitting parts are the upper engine cowlings.Not a problem if you want the engine on display
                          Thanks Dave, be good to follow Peters progress and indeed look at the engine cowling :thinking:. Just wonder why everything lines up but an issue with the cowling.
                          • Dave W
                            • Jan 2011
                            • 4713
                            I thought it was something I had done wrong. But even Barry W had problems with his
                            • peterairfix
                              • Jul 2012
                              • 11144
                              I have got the IP done and all those parts and the pilot.[ATTACH]325873[/ATTACH][ATTACH]325874[/ATTACH][ATTACH]325875[/ATTACH][ATTACH]325876[/ATTACH][ATTACH]325877[/ATTACH]
