An old Walrus coming to life...Matchbox 1/72 kit.
    More nice work Richard :smiling3:.
    • Lee Drennen
      • 7738
      #47
      Richard. Very nice progress I’m liking this build a lot
      • rtfoe
        • 9208
        • Richard
        • Shah Alam, Malaysia
        #48
        Thanks gentlemen. I'm glad you like it. It's been more than a year that I had finished this but haven't actually touched on the weathering. Will do it prior to sending it again for the Penang show under dioramas this time.
        Here are some shots before I added the footprints on the upper wing. Decals weren't provided for that so I had to draw and cut a stencil for the masking.
        The whole aircraft recieved pin washes to the scribed panel lines and an extra amount of dark wash added to the flaps.
        The wash helped bring out detail and just made it a bit more crisp...seriously don't know how to describe it but it's like the image in the lens suddenly is focused sharp.
        After building this Airfix came out with their new tooled Walrus including a 1/48 scaled kit. But I'm still glad I worked on this oldie.
        • scottie3158
          • 14583
          • Holbeach
          #49
          [ATTACH=CONFIG]n1095859[/ATTACH]
          [ATTACH=CONFIG]n1095860[/ATTACH]
          [ATTACH=CONFIG]n1095861[/ATTACH]
          [ATTACH=CONFIG]n1095862[/ATTACH]
          [ATTACH=CONFIG]n1095863[/ATTACH]
          [ATTACH=CONFIG]n1095864[/ATTACH]
          [ATTACH=CONFIG]n1095865[/ATTACH]
          After building this Airfix came out with they new tooled Walrus including a 1/48 scaled kit. But I'm still glad I worked on this oldie.
          Richard,
          That is a great result, your right the pin washes have made the details pop.
          • rtfoe
            • 9208
            • Richard
            #50
            Thanks Scottie, everything was fine until I sprayed a coat of varnish so the dilema hasn't quite finished yet. :smiling2:
            • rtfoe
              • 9208
              • Richard
              #51
              Hi, my first stencils of the boot mark were a little too big. I only realised this after spraying them on. I couldn't remove them so I decided spray over them with the gray and green camo. For this I used blu-tac and masked just a portion and carefully airbrushed the affected area.
              After that I cut new stencils and sprayed the boots one by one...
              • rtfoe
                • 9208
                • Richard
                #52
                Hi,
                This is where I start the diorama build for the Walrus. I will take the opportunity to move this to the diorama section afte I have made an intro into what made me do it then I'll add a link.
                It all started with coming across this thread in the SeaWings - The Flying Boat Website. It had images of a 1/48 scratchbuilt catapult with a Walrus on it...
ID:	1095978 Images for reference only
                And I said I was going to build it if I had the plans...
ID:	1095979 Images for reference only
ID:	1095980 Images for reference only
                Low and behold it came with a set of plans and I set about trying to scale it.
                Lucky for me they had a side profile plan of a Walrus on this same catapult. Using that and measuring it with the kit fuselage length I managed to scale it.
                Before this I had never undertaken such a project. I checked against the Evergreen angled strips available and most matched which made it more easier.
                The build will start in the next thread in the diorama section here. So hop over if you want to see the continuation to the end.
